Regarding ceramic brakes
Hi all,
i have a 2010 Continental Supersports, and it came with ceramic brakes.
The front pads look fine but the rear ones are running thin, wondering if i can just change the pads without changing the rotors (as they are very expensive to purchase) and designed to last over 100k
As Paul stated, just the pads, I though would be checking as to why the rear pads are worn before the fronts, have the fronts been replaced before but not the rears, or are the rear calipers hanging up ?
How many miles ?
Johnny
How many miles ?
Johnny
I bought it at 17k and now it has 27k miles.
occasionally fronts squeal, but my rear pads seems thinner. And i have no idea if any brake jobs were done.
would this be the part number for the front pads and rear pads?
https://www.scuderiacarparts.com/par...ear-indic.html
https://www.scuderiacarparts.com/par...sc-brakes.html
thanks in advance
Front rotors
Front pads
Rear rotors
Rear pads
thanks in advance
Front rotors
Front pads
Rear rotors
Rear pads
Hello @shorttough ,
If you could retake the rear pad picture it would be helpful, it appears out of focus.
As far as the part numbers you listed by link, I have checked them 3 times, only because I didn't like that Scuderia posted the incorrect rotor for the rear ceramic compared to the front ceramic rotor they displayed, but those listings all state "ceramic" for rotors and pads, so it should be good to go, but I would call Peter Ketchen at Scuderia directly to confirm.
Dir Tel: +44 (0)1784 682940 | US: 888-527-9396
As far as your pad thickness, here are some pictures of the calipers from the Supersports salvage vehicle where I got my Supersports engine transmission package from, the Supersports had 11,000 +/- miles on it at the crash, see the pads thickness, they all look like new, front and rear.
2 pictures of the fronts, and 1 of the rear, it's amazing how small the front pads are with those huge calipers.
Johnny
Johnny
Love the red interior of your car. I have the same red interior lightweight seats with carbon fiber back.
I went under the caliper had my front facing camera do a flash.
seems like the angle at which i was seeing made me think it was thinner but apparently not.
So pads are good.
now have to look into how i stop the squeal.
thanks Johnny!
Rear pads
So pads are good.
thanks Johnny!
Rear pads
@shorttough ,
Thank you, I love the red also !
As far as the squealing, it has been said that it is normal, if you watch any YouTube videos of vehicles with the ceramic brakes, they all squeal.
@therron4ou went through all of this back in December of 2015, he was told that the cracks in one of his rotors were to many, and therefore needed replacing, and being that they must be replaced in pairs, it was a experience job, I found a package deal for him at a Florida Bentley dealership for good cost, well, he ended up with the same squealing, after lots of discussion with other owners with ceramics he found that they spray aluminum wheel cleaner on the rotors and let it sit overnight, he said that gets you about 1-2 months of no squealing.
Here is his thread.
https://www.6speedonline.com/forums/...ic-rotors.html
Johnny
Here is his thread.
Johnny
So pads are good.
thanks Johnny!
Rear pads
So pads are good.
thanks Johnny!
Rear pads
Does your 2013 GTC have the ceramic brake system, being ceramic rotors, or do you have iron rotors with ceramic pads ?
Johnny
C
