replacing the brake booster vacuum pump
Old 07-24-2021 | 03:54 AM
BrakeBuster's Avatar
BrakeBuster has a reputation beyond reputeBrakeBuster has a reputation beyond reputeBrakeBuster has a reputation beyond reputeBrakeBuster has a reputation beyond reputeBrakeBuster has a reputation beyond reputeBrakeBuster has a reputation beyond reputeBrakeBuster has a reputation beyond reputeBrakeBuster has a reputation beyond reputeBrakeBuster has a reputation beyond reputeBrakeBuster has a reputation beyond reputeBrakeBuster has a reputation beyond repute
your spotting a trend here arnt you ? lol
replacing all the common fail points on these fantastic cars, well, i do have to get her' just right ' to enjoy her more
the brake vacuum booster pump is mounted in the left wing rearwards of the left front wheel behind the splash guard inner lining, the pump on a frame along with the blue vacuum reservoir is easily removable to work on , the top vacuum hose is a known point to split and cause a vacuum leak , so that was also dealt with while i was there ( it was indeed split)
remove this frame, disconnect the electrical plug to the motor and remove the vacuum pipe, it can be fully removed to work on , again the pump from B is around £600 UK , here we go again , i found a pump for an Audi for £50 uk ( ebay sale ) and it is shown next to my original still mounted in the frame,
this really was a case of , remove the old, clean up , check for any issues, reassemble using the identical Audi pump ( even had the same numbers and stickers !) and fit back to the car, mine was noisy , from age and fighting vacuum leaks all the time i presume, new pump is again whisper quiet ( but i know when its running as i have super power hearing, lol) , the repair of the one Vac leak has helped immensely , but still looking for a very minor leak that the vac reservoir cant hold overnight..but the pump stops after 30 seconds during startup , so not a 'full leak' if you see what i mean..
BB
Old 07-24-2021 | 04:03 AM
CatmanV2's Avatar
CatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud of
In the Maserati world we have an alternate parts thread
If you'd care to list all these fab savings you're finding, I'd gladly start one up
C
Old 05-09-2022 | 04:29 PM
TeamJones1962's Avatar
TeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud ofTeamJones1962 has much to be proud of
Would have been nice to put the model numbers in the thread 🤷🏾
Old 05-10-2022 | 05:39 PM
iSteve's Avatar
iSteve is infamous around these parts
Google Audi Vacuum Booster
it looks like its used on VW Audi Skoda Chrysler also
porsche996tt_tpe
06-20-2017 10:53 AM
ULSTRUP
Bentley
23
04-23-2017 07:27 PM
dynamic gt2
03-21-2010 10:58 PM
Jagman1
Cayenne 955/957
12-10-2009 08:02 PM
Quick Reply: replacing the brake booster vacuum pump
