2012 Bentley GT P0492
Tried searching and couldn't find any additional information. I was tested both air pumps and found both operational. Any tips where else to look? Thanks!
Also check the air intake filter on each SAI pump.
Johnny
I applied power to the air pump motors and listen for leaks but not sure if what I’m hearing is normal. I’ve read guys pressure testing but now sure how I would do so. I pulled the sensors out to try smoking the system and it just smokes out the filter so that didn’t help and the filters seem good when I ran the motors I felt a good suction from the filter side.
i have just bought both SAI pipes for the engine bay that have the pressure sensors on them( pre 2007 MY cars do not have the sensors) ,
the most common place for the plastic tube to crack/break is either side of the sensor fitting, there is a tube for each side, the left bank tube runs right in front of the engine to the multivalve ,i carried out a temporary repair to confirm my issues, and as i said i am now waiting for brand new tubes , which come with all fittings and new sensors to arrive
part numbers are
part 11 in pic 3WO131128N was around £70
part 12 in pic 3WO131128R £130
BB
part numbers are
BB
Global Autosports
Bentley Vendor Classifieds
09-06-2012 12:31 AM
QuickSilver X
Bentley
08-02-2011 10:14 AM
