Constantly topping up oil
Old 09-09-2021 | 02:50 PM
Ryan lafferty's Avatar
Ryan lafferty is infamous around these parts
I have a bentley continental gt with the w12 and 98000kms on it. Iv never had the low oil lite come on but I constantly check the dip stick and oil level is always low so I am adding oil to it monthly. Is this normal?
Side note: there is no blue or black smoke coming out the exaust so I do not think I'm burning oil
Old 09-10-2021 | 09:39 AM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
How many miles are you driving between top ups and just how much oil are you actually putting in the engine every time?
Old 09-10-2021 | 12:17 PM
About 3/4 of a quart every 700kms or so. It seems like alot hahah
Old 09-10-2021 | 01:20 PM
That sounds quite a lot tbh. Is there any sign of a drip anywhere.
What is the published acceptable oil consumption for our w12 engines. For eg my 2ltr Cosworth is 1 ltr /1.76pts per 1000 miles.
Old 09-10-2021 | 02:00 PM
sam08861's Avatar
sam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud of
If you see bluish smoke when on the gas, out of the tailpipe and can't find any leaks externally, you might have to start looking at internal oil seals and gaskets. Some folks on here may know common points of failure might be for these engines. 3/4 of a quart is a fair amount of oil and likely should have some fingerprints.
Might also pull some spark plugs to see if any have signs of oil, which might help narrow things down.
Old 09-10-2021 | 05:22 PM
No smoke out the back at all. took it up on the lift and removed bottom skid plates to find no signs oil leaks anywhere. To be honest it looked like it was just off the showroom floor under there.
Do you ever add oil to you bentley between oil changes ?
Old 09-10-2021 | 05:27 PM
sam08861's Avatar
I've not had to add oil as of yet. Hope you find the culprit.
Old 09-11-2021 | 06:05 PM
1eapplebaum's Avatar
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Not uncommon for the intercoolers to have a couple ounces of oil, over time accumulated within. Worth double-checking, should there be more than a couple ounces. Remove the hose clamps at the lower rubber intercooler hoses under the vehicle next to the bottom of the radiator, right and left.
Old 09-11-2021 | 07:40 PM
Thank you I will check this out and let you know what I find
solrac6262
04-13-2016 08:22 PM
2020
911
01-09-2015 08:27 PM
slicky rick
11-04-2013 06:00 AM
sameerg
11-07-2011 12:59 AM
jabed92694
06-06-2011 11:11 PM
Quick Reply: Constantly topping up oil
