Stock Bentley Wheel bolts are conical or ball seat?
Old 09-28-2021 | 08:37 AM
Arpad's Avatar
Arpad is infamous around these parts
Question are stock Bentley wheel bolts conical or ball seat? I picked up a set of Bentley stock 20" wheels (7 Spoke et 41 part number 3W0601025AA ) to get rid of the prior owners aftermarket salad shooters. I am trying to figure out if the wheel bolts that came with the car will work or not.
I checked flying spurs site and they appear to be ball seat but I am not sure if the picture they have up there is the actual or like some sort of stock photo. The rim feels like its ball seat, I am just trying to confirm my suspicions.
Old 09-28-2021 | 09:56 AM
CatmanV2's Avatar
CatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud of
Get some engineers' blue and check one of the bolts you have against the new wheel?
C
Old 09-28-2021 | 11:59 AM
BWings's Avatar
BWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant future
Stock Bentley wheels/Lug bolts are BALL seat.
I cannot qualify every series all the way up to present date, but the earlier series are.
Old 09-28-2021 | 12:37 PM
sam08861's Avatar
sam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud of
Just did something similar, but went from Bentley 19s to Bentley 20s.
I believe size is M14 x 1.5 pitch thread and 27 mm for all gen 1 and 2 Continentals (not sure newer models).
Just purchased a set of bolts (not Bentley, since I could get 5 for the price of 1 Bentley sourced bolt) to change wheels as I needed to get rid of the 'security bolts' as the Bentley replacements have little plastic lug covers and the bentley wheels being taken off had a central hub cover over all the bolts. Many a VW use the same bolts. I'll look when I get home for the part #, as scuderia has changed these to an non standard (for VAG) part number.
Edit.. Part number is: 8D0601139D
There's also a PDF somewhere on this forum, with a listing of all Bentley Continental GT wheels through 2012 or so, with pictures, weights, width, offset, bolt part #s and recommended 'usage'
If you need the lug bolt covers, they are here (and other places, for less): https://www.scuderiacarparts.com/par...eel-studs.html
Finally, if you need tire pressure sensors, these are readily available at tpms.com.
Old 09-28-2021 | 02:24 PM
Arpad's Avatar
Sam, thank you for that detail. It is a ball seat bolt.
PetesinVegas
Bentley
09-24-2024 10:23 AM
BWings
Bentley
07-10-2019 12:01 PM
Bobby_G
Bentley
11-16-2017 04:02 PM
dksras
Bentley
01-06-2015 03:47 AM
Quick Reply: Stock Bentley Wheel bolts are conical or ball seat?
