Continental GT Rotors
Old 10-03-2021 | 04:04 PM
DR3ADKN0T's Avatar
DR3ADKN0T is infamous around these parts
As I look at the aftermarket for rotors, I notice some state "Left Rear" or "Right Rear". Aren't they all the same or is there a difference front to back, driver's side to passenger side? If so I have no luck finding a full set.
Old 10-03-2021 | 11:11 PM
John Fiammetta's Avatar
John Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond repute
They are not handed , ie a L fits on the R and vv ,
How ever the fronts are larger , significantly larger ( and this is reflected in the price ) than the rears ,
You cannot swap F + R .
So you need two sets , a front set and rear set .Mr Google is your friend .
Its an easy enough DIY job I did a couple of threads on here .
Old 10-04-2021 | 04:59 AM
Lewis Barwick's Avatar
Lewis Barwick is infamous around these parts
Just a guess but looking at your screenshot it shows drilled rotors which I imagine need to be fitted in a certain way so the drilled holes maximise cooling.
Old 10-04-2021 | 06:53 AM
CatmanV2's Avatar
CatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud ofCatmanV2 has much to be proud of
I don't think they do, you know. Certainly I never recall having handed rotors.
C
Old 10-04-2021 | 01:06 PM
sam08861's Avatar
sam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud of
As others stated, doesn't matter.
Thank you by the way John F., I used your writeup when replacing the rears recently.
Perhaps they are setting up the direction of the 'spirals' of the cross drilling to be facing the same direction. As these are to allow hot gasses between the pads and rotor to escape (or liquids in the wet, which become gasses at temp) the "aerodynamics" of the holes should play no significant part other than aesthetics.
alpa6164
Bentley
01-24-2023 06:09 AM
gtjay
Bentley
11-30-2018 12:56 PM
white out
08-27-2017 01:49 PM
VID997
64
01-18-2013 11:54 AM
007 Vantage
01-10-2013 09:41 AM
Quick Reply: Continental GT Rotors
