my Cont gt 2004 Upgraiding to full oprions and solving problems
Old 10-18-2021 | 07:59 PM
molphar's Avatar
molphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud of
I've desided to optimize all info and questions that i had building my car in one topic
So Ill begin from what i got on the start.
Bentley continental gt 2004 with no options exept kessy.
The aim - all options like it was in final version + ventilated seats.
A bit later i will write about every option. Now finished - soft close for doors and motorized trunk, AV input...
Trunk - https://www.scuderiacarparts.com/par...123/2119/38051
All parts are listed there. To install you need some welding and other profetional tools. It was expencive and hard, and chance to find spelialist for this work in USA or EU is low(
So it is possible if you can look and compare construction of car that already has this option. But i do not recomend this work. Buy car after 2006)
Soft close for doors - must have! You will eed middle part of door, motor, latch, wires and module( (3W8959701B 3W8959702B) But, it is simply must have for continental gt.
I'll use link on @Johnny Hotspur GT 's post https://www.6speedonline.com/forums/...ml#post4554938
!!!WARNING!!! there is no safe stop. If you fingers stay in door - they will be brocken. My girlfriend had finger fracture (((( so be carefull
AV-INPUT TV-tuner hybrid version - 3D0919148 tv tuner, in 54pin connector you have
av-1 video - 52,53(ground), audio - 47,48, 49(ground)
av-2 video - 45,46(ground), audio - 40,41,42(ground)
Spoiler
In small 12 pin connector in 2004gt - av-1 video - 4,12(ground) audio - 1,2,7(ground) actualy if device that you gonna connect uses common groung you can do it also, but i like to do like it should be.
but this connector is 7pin, so, i replaced 45, 46 to pins in 54pin connector of tv-tuner to 50,51 so i've made av-2 video input in the same place, on 5,6pin. (i'll try to restore stock couse i don't understand how it happend that 6 is ground) I installed front camera and wired to av-2, also i've paralelled rear camera to aditional rca connector,
Spoiler
if you use 12pin connector (x00528) near right battery part number for other part of it is - 4f0972112
for 3D0919146 (older-analog) tv tuner, in 54pin connector you have, and you dont need to change anything
av-2 video - 50,51(ground), audio is common with av-1
av-2 video - 5,6
Heated 3-spoke steering wheel and all other parts....
So, you need wheel, and two more parts (8E0953541E and 7L6953549L or (7L6953549J 7L6953549G) should also work) that can be taken from touareg gp much more cheaper then from bentley. main thing is that there should be pins in heater connector ) and after that just reinstall control sticks from your on this one, and vsds - 16 block, there will be all instructions.
!!!but it is not that hot you want it to be, so i took one morecomplect of parts to make some tricks with temperature sensor. And as far as I know no one resolved this with coding and adaptation becouse of unknown code for accsess ib 16block
Spoiler
VIM - video in motion. Unfortunately method for a8 and touareg nf is not working, so i ordered unit from kufatec. Strange thing that on the unit tere is no ZAB in the list and often if there is rns810 that version is not for you BUT i don't know how, but it works)
https://www.maxxcount.de/tv-freischa...ental-gtc.html
But as you can see arrived another unit. maybe it is like
https://www.kufatec.com/en/dvb-t-tv-...gtc-2008-33990
I don't know, just look on mine and you can be sure it works
Spoiler
Later i will add photos and vids
Old 01-01-2022 | 08:27 PM
molphar's Avatar
@Johnny Hotspur GT
Need your help ) i wand to make some device than will cheats window brake light. I don't like how it looks like and want to disconnect it. but there is error on dash screen and no one likes it)) so, it is not that easy as with that modules that i made for you. i'm dissapointed that they didn't arrived before hollydays but nothing i can do with it.
so i've discovered all wirings of that stop diod light and. there are two pins easyly reached on the shelf in the boot. There is module - C00408 part number - 3d0959933f
and two connectors x00323(11pin) and x00512 (7pin) that finaly are connected to that stripe of diods. so. I want to asl to connect tester and to see consumption and voltage on both of this pins with stop pressed and without. And then ill make simple-connecting device to cheat that controll module
Spoiler
Or maybe If it is hard for You maybe your know somebody who can do this on this forum, i think it will be usefull for bentley owners.
Old 01-22-2022 | 10:45 AM
molphar's Avatar
@Johnny Hotspur GT
https://www.youtube.com/watch?v=Sl0_9q-S-WA
I regret that i took 2004, it would be better to pay twice more and take 2009y.m. but who knew
Old 02-01-2022 | 07:38 PM
molphar's Avatar
@Johnny Hotspur GT continue of experiments.
in a few days ill have modifyed module to disable third light without any resistors
Old 02-02-2022 | 12:13 PM
molphar's Avatar
Spoiler
BUT!!!! there is no X00282 pinout shematics in my IETIS
@Johnny Hotspur GT maybe there is in yours?
And about PDC screen there is trouble in coding it. it should be 2020002 but 6c (rear camera module) it doesnt takes this coding, only 2000002 or 2010002.
If i translate - +2 in third position means optical parking system. oh, and i restored button of rear camera on pdc screen. it appeared if you out 5 in third symble of 07-module coding.
But still, eve when it accepts coding it is displayed as 0000000. i tryed codings from rosstech forum
Spoiler
So, maybe someone can show his coding oc 6C rear camera module with working PDC SCREEN?
also ill check uo wiring.
it would be much easier to pay twice more for 2009y.m. car ))
Old 02-08-2022 | 05:13 AM
molphar's Avatar
Finally, I've got answers. On bentley cont gt 2009 that my head unit was taken there was 3W0919283D parking distance controll module and 3W3907441 HW: 14 SW: 0023 for camera module
and mine are 3W0919283B and 3W3907441 HW: 13 SW: 0020
So first step will be to change parking distanse to "D" and then i''l try to code 6c - rear camera module with 2020002 coding, if not, ill should upgrade it also.
Old 02-08-2022 | 01:46 PM
Johnny Hotspur GT's Avatar
Administrator
​​​​​​Hello @molphar ,
The only issue with the "D" version is, that it has three plugs, instead of the two that we have, we have a 20 pin plug, and a 16 pin plug, whereas the 2009 and up "D" has one 16 pin, and two 12 pin plugs, BUT, my thinking is that they just changed the wiring layout, where we have the (6 wires) power supply, grounds, and control switch wiring on the 20 pin plug, and both front sensors (8 wires) and rear sensors (6 wires) all on the our 16 pin plug, the "D" version puts all power supplies, grounds, and control switch (now 7 wires, as an additional power supply is added) wiring on a 16 pin plug, and then separates the front ( same 8 wires) sensors, and rear (same 6 wires) sensors and then puts them on each of the two 12 pin plugs, meaning, power and control on a 16 pin plug, front sensors on a 12 pin plug, and rear sensors on a 12 pin plug.
The pin outs of the "D" version is different from the two plug previous versions, so we have to work that out with the schematics.
I honestly can not believe that Bentley did not include graphic PDC until the 2009 model, my 2005 A8L W12 has it...
Old 02-08-2022 | 04:03 PM
molphar's Avatar
Yes, i know about three plugs, but, this is much more easier then replantation of gauge and fbcm((((( One more service failed. so ill go another way, keep new gauge(couse old don't have safe lines on pdc) but old fbcm. and try to fix three bugs. turn repeters on gaugeboard, overheating error and gasoline level. They changed a lot in wiring. what for? to make it impossible to simple retrofitting? it is rethorical question...
And how it is possible that car for 300k didn't have al that usual things for cars that years premium.
hueyy702
Bentley
11-16-2016 09:59 AM
ExSF
Bentley
17
03-10-2014 01:25 PM
Frank ( Sunnyside )
05-09-2013 04:10 PM
Tmainevent
Bentley
14
04-13-2011 06:44 PM
Quick Reply: my Cont gt 2004 Upgraiding to full oprions and solving problems
