Third brake light error disabling
Old 01-28-2022 | 10:46 AM
sam08861's Avatar
sam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud ofsam08861 has much to be proud of
fyi... found this... https://www.topeuromachine.com/produ...r-kit-2pcs-646
edit... they are simply 50w/6ohm resistors for those that may have electronic parts around or want to get them locally. Ordering these from Amazon to try out.
Amazon Amazon
ps.... Resistors don't care about polarity, so no worries about wiring incorrectly.
Old 01-28-2022 | 11:00 AM
molphar's Avatar
molphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud of
As I told you in another thread this resistor will be hot. Too hot. you can watch video with similar construction fot turn light. It is completley failure. 100+ celsium. hot as hell, so ive made another system, and tested temp. in is not more then 60c for 10 mins of working.Hope soone we will see one more test from well know person here)
Old 01-28-2022 | 11:05 AM
sam08861's Avatar
I was thinking to install the resistor further up the wiring, rather than having to open up the hard to reach rear area, so as to find a place that can dissipate the heat, perhaps under the hood or under in a body cavity with only metal. Where I am, not so much time spent sitting on the brakes and if it's a complete stop more than a minute, I usually throw it in park for safety, even at long lights.
also, just fyi.. wirewound resistors are good for around 300 celsius so no worries about the resistors frying. Just need to find an appropriate location and heat-sinking. One more option is to wire a few smaller resistors in series to get the same overall resistance and spread out the heat dissipation into several places.
Old 01-28-2022 | 11:12 AM
molphar's Avatar
I don't know. in slow moving traffic ja, when you start and stop very pften it is benner to have more safe setup. still, ill post when it will be readu, and ive got thermalvisor ) hope - next week.
jayi836
03-25-2014 07:54 PM
gnorwoo
02-28-2014 12:45 PM
123packman
07-22-2009 12:09 PM
p5hrr
06-30-2009 05:49 PM
Quick Reply: Third brake light error disabling
