Heater blowing cold
I have seen 5 litres for £11.00 on Amazon, it is by MANNOL a german company, it is the pink Coolant G12+ MEETS THE SPECIFICATIONS TYPE Ready-to-use Coolant Fluid (-30 °C) SAE J1034 JASO M325 AFNOR FRANCE NF R15-601 (except for RA) ASTM USA D3306 ASTM USA D4656 ASTM USA D4985 ASTM USA D6210 BSI GB BS 6580:2010 FVV GERMANY Heft R443 KSM SOUTH KOREA 2142 MIL BELGIUM BT-PS-6
It is OAT,
Not sure if this will do, but need to do a flush ASAP as worried what damage existing coolant is doing.
It is OAT,
looks good to use. g12+ may have replaced g12. Anyway a good flush and fill with the g12+ should be good for 5 years.
E
The car has been booked in Monday for the flush, I have purchased 20 litres of g12+, pink colour
The mechanic will flush it out and use the 19 litres coolant, he has told me that he wants to do it again a week later and that way the crap is fully removed, so will get another 19 litres.
today I let the car run a while and the middle vents do work on economy so there is some heat, however, it is not the correct temperature and also goes cold when economy is switched off.
I think the flush should really help.
