New to me 04 GT No Start/Electrical Issue Help
Old 02-12-2022 | 08:32 AM
V12diablo's Avatar
V12diablo is infamous around these parts
Cabin fuse box with key on (not running) had no power to these:
58 unused - fuse in this location
59 5 A Rear Body + Tail lamp (CM)
Fuse no. Rating Circuit protected
60 10 A Air suspension (CM)
61 5 A ABS (CM)
62 5A Global close switch
63 5 A
Front body (CM)
Light switch
Telephone (CM)
64 5 A Steering column (CM)
65 10 A Park heater replacement coolant pump
66 5 A HVAC (CM)
HVAC compressor
67 10 A Transmission (CM)
ESP switch
68 5 A Gearchange switch
Park solenoid lock switch
69 5 A Electronic park brake (CM)
70 5 A Speed sensitive steering (CM)
71 5 A Active rear aerofoil (CM)
72 5 A Air quality sensor
73-77 unused (still fuses in these locations)
78 rear seat heaters
Engine compartment fuses with key on (not running) had no power to these:
4 5 A Front body (CM)
14 20 A Park position heater
Heated element washer jets
29 50 A Secondary air injection pump 1
30 50 A Secondary air injection pump 2
Rear fuse box had power to all fuses
I will be trying to get the Kessy box out this afternoon. Terminal 30 would be the pin 30 on the ECU? Still learning this stuff and want to be sure.
Jason
Old 02-12-2022 | 10:41 AM
Johnny Hotspur GT's Avatar
Administrator
Hello Jason @V12diablo ,
Ok, you say rear fuse box, but did you check the mega fuses under the black plastic cover, see picture below.
Terminal 30 is a constant power source, likely the 80/100 (depending on year for amperage) amp mega fuse, or the 150 amp,
terminal 15 is an ignition activated power source, then there are also timed power source terminals, what is odd with the Bentley IETIS, it doesn't list these as say terminal 30, like the fuse layout for an Audi A8L W12 does, but terminal 30 has to be one of the mega fuses on the house battery, that's where the constant power would come from to feed the other fuse boxes.
If any of the mega fuses are blown, I really wouldn't recommend replacing or jumping it until the cause of blowing it if rectified.
As to your scans, your immobilizer is active, therefore killing the engine after 2-3 seconds, this is most likely tied to the KESSY module getting wet, or the ecu's getting wet, I am leaning towards the KESSY module sitting in water, eventhough the carpet may seem dry on top, the molded base of the carpet is a foam, and is not breathable to let it air out..
Johnny
Old 02-12-2022 | 11:08 AM
V12diablo's Avatar
I did miss those. I will check them shortly and report back.
Jason
Old 02-12-2022 | 11:11 AM
Administrator
@V12diablo ,
There are also HSB/strip fuses in the black box on top of the starter battery.
Johnny
Old 02-12-2022 | 02:05 PM
V12diablo's Avatar
Ok, I check all the maxi fuses as suggested on both batteries, no issues there. I removed and inspected the Kessy and it was dry. I also inspected the circuit breaker box while I was there. See attached pictures. I am leaving on vacation tomorrow and will get back on it this coming weekend and will update then.
Old 02-20-2022 | 02:44 PM
V12diablo's Avatar
So I made sure the batteries where both at 100% charge when I got back. I cleared all the codes again by each module, and now it will not turn over again, it says to press the brake pedal like last time. I rescanned the codes and they are listed below. I am starting to think it is definitely a issue with the module or the can bus system, I inspected the wiring at the 2 modules in the engine bay under the windshield on the passengers side and found some of the wiring had been repaired previously. Does anyone have a wiring/pinout diagram for those modules. I would like to start testing them to see if there is a issue there.
Jason
Code:
VIN: SCBCR63W04C022240 Mileage: 168790km-104881miles
Address 01: Engine Labels: 07C-906-018-BEB1.clb
Part No SW: 07C 906 018 J HW:
Component: BY-6.0L-TT G ª6240
Coding: 0000173
Shop #: WSC 01666 772 36780
VCID: 2C010BE8AA162EBB2B9-513C
VINID: 8D34938860E70044C008208400746ACBC3
13 Faults Found:
18347 - Powertrain Databus
P1939 - 008 - Missing Message from Controller for Access & Start Auth.
18045 - Powertrain Data Bus
P1637 - 008 - Missing Message from Electric Load Controller
18044 - Powertrain Data Bus
P1636 - 008 - Missing Message from Airbag Controller
18036 - Powertrain Data Bus
P1628 - 008 - Missing Message from Steering Angle Sensor
18043 - Powertrain Data Bus
P1635 - 008 - Missing Message from A/C Controller
18034 - Powertrain Data Bus
P1626 - 008 - Missing Message from TCU
18057 - Powertrain Data Bus
P1649 - 008 - Missing Message from ABS Controller
18107 - Powertrain Data Bus
P1699 - 008 - Missing Message from Steering Wheel Electronics
18058 - Powertrain Data Bus
P1650 - 008 - Missing Message from Instrument Cluster
17972 - Throttle Actuator (J338)
P1564 - 002 - Under-Voltage during Basic Setting
16885 - Vehicle Speed Sensor
P0501 - 004 - Implausible Signal
18331 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 09E 927 760 D HW: GS1 904 1
Component: AG6 09E 6.0L W12TT 1904
Coding: 0000101
Shop #: WSC 00000 000 00000
VCID: 313F1A9C8D34435318F-5160
1 Fault Found:
18258 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 168798 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 3.0°C
T.B. Angle: 60.0°
Address 03: ABS Brakes Labels: 3W0-614-517-V1.lbl
Part No: 3W0 614 517 F
Component: ESP 5.7 4WD H01 0047
Coding: 0007878
Shop #: WSC 12345 000 00000
VCID: 382927B86E4E921B5F1-51CE
3 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 M HW: 5WK 470 26
Component: 11 Kessy 6400
Coding: 0131309
Shop #: WSC 00083 000 00000
VCID: 2F3B1CE49B0055A30EB-5160
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
3 Faults Found:
01333 - Door Control Module; Rear Left (J388)
01299 - Diagnostic Interface for Data Bus (J533)
013 - Check DTC Memory
Address 06: Seat Mem. Pass Labels: 3W0-959-759.clb
Part No: 3W0 959 759 A
Component: CM Seat Pass. 0009
Coding: 0000002
Shop #: WSC 34183 002 1048576
VCID: 47CB544413B0EDE326B-5160
5 Faults Found:
01900 - Passengers Seat Fore / Aft Adjusting Motor (V31)
005 - No or Incorrect Basic Setting / Adaptation
01975 - Passengers Seat Height Adjustment Motor (V191)
01904 - Passengers Backrest Adjusting Motor (V46)
01903 - Seat Tilt Adjustment Motor (V231)
01976 - Seat Depth Adjustment Motor (V234)
Address 07: Control Head Labels: 3D0-035-00x-07.lbl
Part No: 3W0 035 008 FX
Component: ZAB COCKPIT 0251
Coding: 0400325
Shop #: WSC 03224 104 175128
VCID: 084997785E2E229BEF1-5160
1 Fault Found:
Address 08: Auto HVAC Labels: 3W7-907-040.clb
Part No: 3W0 907 040 B
Component: Climatronic BY614 0030
Coding: 0000002
VCID: 30391F98863E4A5B171-5160
1 Fault Found:
01312 - Powertrain Data Bus
Address 09: Cent. Elect. Labels: 3D0-937-049-V1.clb
Part No: 3D0 937 049 G
Component: STG.Bordnetz 5001
Coding: 0000107
VCID: 2E0501E09C0A5CAB05D-5160
2 Faults Found:
Address 11: Engine II Labels: 07C-906-018-BEB2.clb
Coding: 0000173
2 Faults Found:
19490 - Intake Air Temperature Sensor 2 (G299)
P3034 - 002 - Signal too Large
P3034 - 002 - Signal too Large - Intermittent
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 E
Component: 0P Airbag 8.4E+ H10 0936
Coding: 0012368
VCID: 2517FECCC9FC1FF3F47-5160
No fault code found.
Address 16: Steering wheel Labels: 3D0-953-549.lbl
Part No: 3D0 953 549 D
Component: Lenksäulenmodul 3401
Coding: 0000012
Address 17: Instruments Labels: 3Wx-920-xxx-17.lbl
Part No: 3W0 920 840 Q
Component: KOMBIINSTRUMENT RB8 0401
Coding: 0023200
VCID: 42DD45503892C8CBF15-5160
2 Faults Found:
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70B9DF9846BE0A5B571-5160
2 Faults Found:
Address 34: Level Control Labels: 3D0-907-553-V1.clb
Part No: 3W0 907 553
Component: LUFTFDR.-CDC- 3C1V0 7014
Coding: 0015500
VCID: 77ABE48423D05D6396B-5160
2 Faults Found:
00778 - Steering Angle Sensor (G85)
Address 36: Seat Mem. Drvr Labels: 3W0-959-759.clb
Part No: 3W0 959 760 A
Component: CM Seat Driver 0008
Coding: 0000002
VCID: 3FDB4CA44B60A5239EB-5160
11 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
02569 - Control Module for Massage (J740)
009 - Open or Short to Ground - Intermittent
00997 - Motor for Driver's Seat Position; Fore/Aft (V48)
011 - Open Circuit - Intermittent
012 - Electrical Fault in Circuit - Intermittent
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
004 - No Signal/Communication - Intermittent
01174 - Driver Seat Height Adjustment Motor (V138)
00998 - Motor for Driver's Seat Recline (V45)
01895 - Motor for Steering Column Adjustment; Vertical (V123)
01896 - Motor for Steering Column Adjustment; Axial (V124)
Address 37: Navigation Labels: None
Part No: 3W0 919 887 A
Component: NAVIGATION 0168
Coding: 0400000
VCID: 45D75E4C29BCFFF3D47-5160
Address 38: Roof Electronics Labels: None
Part No: 3W0 907 135 C
Component: Dachmodul 0702
Coding: 0000189
VCID: 36352980645A646B4DD-5160
Address 46: Central Conv. Labels: 3D0-959-933.lbl
Part No: 3D0 959 933 F
Component: 1F HSG 0101
Coding: 0000032
VCID: 33331094772871436A3-4B00
Subsystem 1 - Part No: 3W1 959 701
Component: Tuersteuergeraet FS 0702
Subsystem 2 - Part No: 3W1 959 702
Component: Tuersteuergeraet BF 0702
Subsystem 3 - Component: TSG HL No Answer
Subsystem 4 - Part No: 3W3 959 704
Component: Tuersteuergeraet HR 0702
Subsystem 5 - Part No: 7L0 907 719
Component: Neigungssensor 0020
1 Fault Found:
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 3W0 035 456 C
Component: 12K-AUDIOVERST 4121
VCID: 343113887226767B739-5160
Address 53: Parking Brake Labels: 3W0-907-801.clb
Part No SW: 3W0 907 801 B HW: 3W0 907 801 B
Component: EPB BC6HX23 HC6 X230
Coding: 0022401
VCID: 35372E8C795C6F73447-5160
1 Fault Found:
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 4
Fault Frequency: 51
Reset counter: 8
Time Indication: 0
Freeze Frame:
Voltage: 10.25 V
Count: 241
Address 54: Rear Spoiler Labels: 1C0-959-733.lbl
Part No: 1C0 959 733 H
Component: Heckspoiler 0002
VCID: 30391F98833E4A5B171-5184
Address 65: Tire Pressure Labels: 3D0-907-273-V1.clb
Part No: 3W0 907 273
Component: Reifendruckueberw. 0022
Coding: 0010344
Shop #: WSC 03236 104 61216
VCID: 76B5E98024DA246B8DD-5160
1 Fault Found:
013 - Check DTC Memory - MIL ON
Address 68: Wiper Electr. Labels: 3Wx-955-023.clb
Part No: 3W1 955 023 C
Component: WischeX
Shop #: WSC 00000 725 65552
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 C
Component: Batteriemanagement 2700
VCID: 2313E0D4C7C8E1C39A3-5160
1 Fault Found:
Address 76: Park Assist Labels: 3W0-919-283-V1.clb
Part No: 3W0 919 283
Component: 02 Einparkhilfe 0203
VCID: 7AADFDB010C2400BE95-5160
Address 77: Telephone Labels: None
Part No: 3W0 035 729 K
Component: Telefon 0252
End----(Elapsed Time: 06:54, VBatt start/end: 12.0V/12.0V. VIgn 0.0V)------
Old 02-20-2022 | 03:48 PM
Administrator
Jason @V12diablo ,
That does not look good it all, even the covers for the ecu plugs are missing, I wish you would have checked or posted that picture before digging into the KESSY, I am sending you a PM, I wish I was closer, you are a 4 plus hour drive for me, each way...
Please tell us, when this vehicle sat for the period of time while you worked on the Vette, was it outside, rain, snow, or has it been bone dry indoor storage ?
Johnny
Old 02-20-2022 | 05:37 PM
V12diablo's Avatar
Unfortunately it was outside in the snow, I don't remember much rain during that time period. I will dig into the wiring this week.
Jason
Old 02-22-2022 | 05:38 PM
Administrator
@V12diablo ,
I just wanted to be sure that you have checked the 150 amp mega fuse on the top of the house battery, not just the 4 on the front of the battery, see pictures below, I believe this is the lead that feeds power to the dash fuse panel.
Also, your prior scans are showing the battery at 10.2 volts, and 9.2, and your latest scan shows 10.25 volts.
Johnny
Old 02-22-2022 | 07:03 PM
V12diablo's Avatar
Yes, I did check that fuse, but I will double check it. The battery was definitely at 12.5 plus volts and I left the charger/Mai tai er on the main battery while doing all the test, so for some reason I am getting a voltage drop. I am going to test voltage at all the fuses tomorrow when I can work on it again. I am expecting my new back probe and long lead kit tomorrow so I can start testing wire continuity on the can bus system and engine module wiring.
Jason
Old 02-27-2022 | 02:07 PM
V12diablo's Avatar
Well the car is running again. I removed the ECMs and tested the CANBUS system and that appeared ok, I thought the ohms to the Diag port where high but there was continuity. When I check power to the ecms both number 3 pins had nothing. I back traced it to the number 10 fuse in the engine bay fuse box and found it to be blown. I didn't think to actually check that fuse for continuity earlier because it was not powered with the key in the run position. I did ohm out from the fuse to ecms to check for shorts and they appeared good. I havent been able to drive the car yet to reset some of the systems do to snowing conditions we are having today. But here is the most current scan after running for 15 minutes.
Code:
Sunday,27,February,2022,16:06:26:53661
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: SCBCR63W04C022240 License Plate:
Chassis Type: 3W (3W - Bentley Continental (2004 > 2007))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
Coding: 0000173
VCID: 2C010BE8AA162EBB2B9-5160
3 Faults Found:
P1923 - 008 -
18047 - Accelerator Position Sensor 1/2 (G79/G185)
P1639 - 008 - Implausible Signal - Intermittent
17994 - Engine Mount Solenoid Valves (N144/N145)
P1586 - 001 - Short to Plus
Coding: 0000101
2 Faults Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 40
Mileage: 168798 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 159.0
Temperature: 19.0°C
T.B. Angle: 0.0°
18269 - Throttle Position Sensor (G79)
P1861 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 168798 km
Time Indication: 0
Coding: 0007878
2 Faults Found:
000 - -
Coding: 0131309
Component: ELV XXXX
1 Fault Found:
Coding: 0000002
5 Faults Found:
Coding: 0400325
1 Fault Found:
Coding: 0000002
Coding: 0000107
2 Faults Found:
00907 - Intervention load Management
000 - -
Coding: 0000173
4 Faults Found:
19475 - Valve for Exhaust Flap 1 (N321)
P3019 - 004 - Open Circuit
17577 - Mass Air Flow Sensor 2 (G246)
P1169 - 001 - Short to Plus
Coding: 0012368
Coding: 0000012
Coding: 0023200
1 Fault Found:
Coding: 0000006
1 Fault Found:
Coding: 0015500
2 Faults Found:
01400 - Suspension Level Control
Coding: 0000002
6 Faults Found:
Coding: 0400000
Coding: 0000189
Coding: 0000032
1 Fault Found:
1 Fault Found:
00871 - Bass Speaker Front Right (R23)
011 - Open Circuit
Coding: 0022401
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 27
Time Indication: 0
Freeze Frame:
Voltage: 11.39 V
Count: 226
VCID: 30391F98833E4A5B171-51A8
Coding: 0010344
Component: WischeX
End----(Elapsed Time: 06:47, VBatt start/end: 13.7V/13.8V. VIgn 0.0V)------
Old 02-27-2022 | 02:33 PM
Administrator
@V12diablo ,
Well that is great to hear !
Now to find what blew the fuse, I think most likely sitting outside in the snow, snow melting and water getting into areas it shouldn't.
The other thing that is odd, is how many times that fault comes up for the rear left door module, it doesn't have a rear left, it is a GT (2 door) correct, are you selecting the proper model to scan ?
Johnny
Old 02-27-2022 | 05:31 PM
V12diablo's Avatar
Yes, I believe 3w is the model code I put in for the scan. I was thinking the same thing regarding the snow melt. I will hopefully get to drive it in the next couple days. I also think I found my air suspension issue, my front suspension drops after a few days. I found a leaking fitting on the right front strut. I tried to get it to stop leaking by removing the fitting and cutting the line shorter and reinstalling the fitting. It still leaking so I order a new fitting. I should have it in a few days and we will go from there.
Old 04-03-2022 | 03:45 PM
V12diablo's Avatar
Just a update. I've been working on this off and on the past few weeks. I finally determined the issue was a power issue to the ecms. i checked all fuses related to the ecms as one was blown before. I found no issue there. I did find one of the power relays for the ecms looked kind of iffy(167). I replaced that relay , cleared all the codes, started and ran the car multiple times and rescanned. All the codes related to the ecms/ intermittent power/can bus are now gone! Also the issue with pressing the brake while starting has gone away. Now to get my air suspension leak fixed. Thanks for everyone's help.
Jason
crusher
Bentley
14
10-26-2023 02:45 AM
massf
Bentley
05-12-2018 03:15 AM
minming
11-04-2016 11:14 PM
compositeguy
10-23-2016 11:50 PM
Rabent
Bentley
03-12-2016 03:57 AM
Quick Reply: New to me 04 GT No Start/Electrical Issue Help
