Bentayga W12 P2440 & P2442 Error codes. Secondary air injection valves
Hi, the car is reading the P2440 and P2442 error codes. From looking online it has something to do with the secondary air injection valves not closing properly. Is anyone familiar with this issue? Does a part usually need replacing etc.?
2018 model
2018 model
I’ve done a few checks. I checked that what I think are the secondary air intake pumps work. They do. I’ve removed the outlet air hoses from the pumps and blown into them to check if the valves to the exhaust are stuck open (as the error code suggests). They’re definitely not stuck open. A wire on the cable attached to one of the sensors is slightly frayed. Could this be causing the error code?
