Bentley has these trouble codes
I would like to ask if you have encountered this type of fault code
I can't delete it. There is a 10A burnt in the front fuse box, and it burns out immediately after replacing it.
I would like to ask where the problem might be
please help
thanks
please help
thanks
Spoiler
Hello
The Chinese one is read with VCDS because I don't have an English version of VCDS
I used ODIS today to read this in English please help
The fuse location corresponding to the fault is found to be this 10A, but I don't have a fuse diagram for 2013, only before 2010, so I don't know the correct location, so I don't know which direction to check....
please help
looking forward to your reply
thanks
please help
thanks
Hello @Kingwu ,
It would really help if you had the scan results in English, as the numbers do not make much sense, which type of scanner are you using, Ross-Tech VCDS, ODIS, VAS 5054, or a generic scanner ?
Johnny
Johnny
Lotsofproblems
Bentley
10-10-2019 06:30 PM
