Garage Door Opener for older cars (Older than 2012)
Old 04-03-2022 | 04:15 PM
Camaz's Avatar
Camaz is infamous around these parts
Hello everyone
I recently bought a 2010 Bentley Continental GT Speed and i have been trying to program the car to open my Liftmaster / Chamberlain Garage Door without success
I contacted Liftmaster on their chat line and they informed me that the "Homelink" system in the car would not work as it was incompatible - it only works with cars 2012 or younger
(this applies to all models of car and you can check out your own car's compatibility on the Liftmaster website)
After some research, I found that I would require something called a "Compatibilty Bridge" to act as an interface between the car and the Garage door control unit
I purchased a unit called "Liftmaster 855lm Chamberlain OEM Homelink Compatibilty Bridge" for $34.95 from Amazon and it arrived today
I followed the simple instructions and I am pleased to inform you that the system is now fully operational - it only took me 20mins to complete the task
So if your car is older than 2012 and you cannot get your Garage Door to open from your car I would strongly recommend that you get your self one of these units
Good Luck
Old 04-03-2022 | 06:06 PM
BWings's Avatar
BWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant futureBWings has a brilliant future
Yes, I can confirm. I have a new home with the same liftmaster that uses the new SW and the MyQ app. Agreed, that older MY cars with homelink will not program w/o the compatibility bridge. I believe you can also get the bridge at Home Depot
Even with my much newer cars, circa 2018, the linkup was difficult.
Sly Tuna
Bentley
28
07-03-2024 12:21 PM
Bentley Beast
Bentley
10-12-2017 06:15 PM
tranquility
Garage Forum
05-18-2009 11:04 AM
SHANKENFELTER
03-01-2005 08:57 AM
Quick Reply: Garage Door Opener for older cars (Older than 2012)
