2007 Continental GT rough idling
Old 06-13-2022 | 02:36 PM
2007Conti's Avatar
2007Conti is infamous around these parts
This is the cutter. Any bending I did, I did by hand
Amazon Amazon
  #32
Old 06-13-2022 | 03:04 PM
m12volt's Avatar
m12volt is infamous around these parts
https://www.amazon.com/dp/B003BZLISE...roduct_details
Thanks !
So I looked under the hood pictures on @Stevieshutts
post , looks like the only line he connected to was #1 on my picture , what about #2 and #3 intake lines , do they remain untouched ?
  #33
Old 06-14-2022 | 09:57 AM
m12volt's Avatar
Any advice ?
  #34
Old 06-14-2022 | 12:52 PM
2007Conti's Avatar
Leave 2 and 3 alone
  #35
Old 06-14-2022 | 02:00 PM
m12volt's Avatar
So I removed the passenger side wheel well and it's different from Steve's picture , there is a manifold pressure sensor sitting on the vacuum line that's going from the engine bay to the back of the car.
Should I connect my bypass line before the sensor ?
  #36
Old 06-14-2022 | 03:13 PM
2007Conti's Avatar
That's the line to the muffler. Include a T there to allow air to go to the controller AND to the firewall
  #37
Old 06-14-2022 | 03:29 PM
m12volt's Avatar
Well , it looks different , Steve didn't have that sensor
Here is his picture:
  #38
Old 06-14-2022 | 04:25 PM
2007Conti's Avatar
OK I did have the sensor. Either bypass it, include it or remove it. Your choice
  #39
Old 06-14-2022 | 06:55 PM
m12volt's Avatar
It looks like it's working !
I haven't driven it yet , but rough idling is gone , pump doesn't activate with brake , no leaks , no CEL.
I've done it a shorter way though , instead of using a T and running a new line all the way around the subframe , I ran a new line directly from the pump to where the bulkhead hose connects through the steering rack cavity , connected a new line with a T and continued the new line to a passenger side wheel well through the steering rack cavity, connected a new line before the sensor , I used about 7 feet of the line , one T and two straight fittings.
That's it.
Driver's side connection to the pump
New line going to the engine bay
New line connection on the passenger side
T connection to where the bulkhead hose was
  #40
Old 06-16-2022 | 05:11 AM
Samhain's Avatar
Samhain is infamous around these parts
Awesome!
  #41
Old 06-16-2022 | 02:49 PM
m12volt's Avatar
It was a great experience , appreciate everyone's help !
  #42
Old 06-20-2022 | 12:24 PM
silvertonesx24's Avatar
silvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud ofsilvertonesx24 has much to be proud of
Nice work. I did a version of this mod myself and it's held up for almost 2 years so far. The only issue that I had/have was that with the bypass line fully connected, upon acceleration (and only acceleration, not braking) the vacuum pump would turn on very briefly.
Assuming that this was because my bypass line added more length to the system, I disconnected the part of the line that goes to the exhaust valves and the evap purge valve I believe. This solved my problem, although I do get a CEL every so often (500 miles? Not sure) for the purge value being inoperative. I'm not sure how to fix it yet.
Do you have no more vacuum pump noise, even under acceleration?
  #43
Old 06-20-2022 | 04:08 PM
m12volt's Avatar
No more vacuum pump noise , I guess because I did it a different way without adding any extra length , I only used about 7 feet line for my bypass and it's basically the same length as a factory hose.
Thanks for your help !
  #44
Old 06-20-2022 | 04:11 PM
If I'm reading this correctly, you ran a new line behind the steering rack, parallel to the original line? Mine is a bypass route that goes below the engine, then back up to the wheel well. I then capped off both ends of the old leaky line that ran behind the steering rack
  #45
Old 06-20-2022 | 04:28 PM
m12volt's Avatar
Correct , beside the steering rack , then installed T , connected to the engine instead of the old hose and continued to a pass. side wheel well beside the steering rack.
Quick Reply: 2007 Continental GT rough idling
