2007 GT Coolant leak ?
So it looks like I fixed the misfire problem , replaced 1 ignition coil , the car is finally flying as it should , no CEL , no codes.
I took it for a test drive and came back very happy with a result , then I saw 2 small puddles under the car behind the engine , in the cats area , looks like it's dripping from the exhaust pipe.
The liquid looks clear , first I thought condensation from AC , but it's to far behind.
Is this a coolant line to transmission or rear differential or am I just paranoiac ?
