Replacement upper control arm grease boots
Old 07-05-2022 | 07:15 PM
V12diablo's Avatar
V12diablo is infamous around these parts
When I was changing the CV boots on my 04 GTs , I noticed my one of my upper boots was torn, and the other was developing cracks. I didn’t want to replace the upper arms as the joints where still holding grease and where tight. I started searching the internet for replacement boots. After quite a search I came across Specialty Products Companies replacement boots for Audi upper control arms, part number 81354. They didn’t have dimensions but the looked the same. They where $12 for a set so I ordered them and gave them a try. Once I received them I put them side by side the look to be identical except the new ones have a slightly smaller inner diameter. I filled the but with new grease and it went right on. I used the new snap ring at the top and used the original on the bottom since it was much easier to install. Hopefully this will be ove some help to others.
Old boot before removal
New boot installed
Both boots replaced, and I know the nut hasn’t been put on yet.
Side by side , new on right
Side by side, new on top
ciaka
02-15-2024 08:48 PM
DogWood
02-08-2020 07:47 AM
Rat3d M
07-11-2017 11:28 AM
pumalex
08-13-2011 06:54 PM
DM1
944 Turbo & Turbo S
09-25-2009 01:09 PM
Quick Reply: Replacement upper control arm grease boots
