Bentley continental 2005 parking break issue ( p) .. tried all advise on forum
Old 03-01-2023 | 10:12 AM
Rich-dr1's Avatar
Rich-dr1 is infamous around these parts
Hi everybody
I have followed and used this thread many times and always found the answer to my questions, SO MANY THANKS TO ALL.
However not this time
When i bought the car the (p) warning light was not on ..obivously we tested everything 3 times over and applied the parking brake a few times !
This is when The (p) light came on, i followed all advise on here, EVERYTHING WAS WORKING FINE parking brake engages , just 15 seconds after start up the (p) would come on and a loud beeep would ring 3 times. I bought one NEW motor, swapped one side, still the same, then i swapped the 'used motor' with the other side, still the same, removed and inspected inside the switch, bought a brand new oem switch as I read this is common fault, still the same, I have tried 'pinging' it ( holding button on and off for 15 seconds 3,,4 times .. still the same .. all working perfect can clearly hear both motors engage. but light and beep appear 15 seconds after start up .. and (p) remains ( no other warning lights are on )
ANY ADVISE GREATLY APPRECIATED
Old 03-01-2023 | 06:53 PM
1eapplebaum's Avatar
1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of1eapplebaum has much to be proud of
Best to scan the parking brake module with VCDS. Without quantity data regrettably it's a guess. In this case a P brake trouble fault would be a good lead.
Old 03-01-2023 | 07:45 PM
Rich-dr1's Avatar
Many thanks, its going into bentley garage in the next weeks, just trying to solve this issue before it goes in.
ran an obd and nothing came up ..no fault ?
Old 03-01-2023 | 07:59 PM
Unfortunately a generic OBD scan can't investigate the P brake module. Only VCDS and similar devices can. Various other modules on a B are not supported by "OBD" as well. Check out Ross Tech VCDS on line. The setup pays for itself the first time... about 200 US$.
Old 03-02-2023 | 05:34 AM
Rich-dr1's Avatar
Many thanks.. will certainly look at this,
i bought a 'vag obd eleven' works very well on every day issues.
Old 03-02-2023 | 06:41 AM
Originally Posted by Rich-dr1
Many thanks.. will certainly look at this,i bought a 'vag obd eleven' works very well on every day issues.
The OBD 11 is supposed to support all modules VAG including Bentley. However I am not familiar with that particular unit's application. There may be an online forum for OBD 11. ​​​​​​​Please let us know when your car issue is resolved.
Old 03-02-2023 | 07:01 AM
Rich-dr1's Avatar
Will do. So annoying that everything works but the warning (p) comes on at start
cerex
Bentley
05-04-2021 05:29 PM
brady17
Bentley
10-04-2020 01:37 PM
cduluk1
Bentley
23
09-27-2016 01:16 PM
bentleydriver05
Bentley
11-24-2014 12:42 PM
Tintin
Bentley
12-16-2013 03:16 PM
Quick Reply: Bentley continental 2005 parking break issue ( p) .. tried all advise on forum
