krown - worth doing it?
Old 03-11-2023 | 12:37 AM
sazam's Avatar
sazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud of
Hi,
I am cental europe, melty climate, especially in this century - no real winter, no real spring, sudden tropics in summer, then again melty autumn style...
how GT is rust protected?
worth to do this?
https://www.krown.com/en/
anyone experienced with krown solution / or maybe other?
and additional question about technology holes in doors, or in the car thresholds. Are there any, under plastic covers etc? Anyone who has experience with the car disassembling
Old 03-11-2023 | 11:35 AM
BruceR's Avatar
BruceR is infamous around these parts
How is the car holding up? If after 18 years there's no, or very little, rust I'd say they did a good job.
Old 03-11-2023 | 12:08 PM
sazam's Avatar
yes, indeed, there is zero rust...
Old 03-12-2023 | 12:41 PM
Mars911's Avatar
Mars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond repute
Sazam,
See John Fiammetti's post 26 on the following link on what he does to weather proof his every six months. As far as car disassembly ready Johnny's rebuild front to back and then read it again after going and looking at your car.
https://www.6speedonline.com/forums/...me-time-2.html
Old 03-13-2023 | 04:40 PM
dangme55's Avatar
dangme55 is infamous around these parts
If you are really concerned with rust and corrosion there is an aviation product called Corrosion X. It come in a spray can and can be used through one of those plastic nozzle extensions. It is used extensively in aviation. It creates a di-electric film in cracks and crevices. It 'creeps' with a vengeance which adds to its effectiveness. The 'creep' attribute also means that it will 'creep/seep' for a good while and needs to be cleaned up several times.
It can be sprayed in rocker panels, access plugs in doors, yada yada.
It is fairly expensive but really works well. Corrosion is a big problem on aircraft and it has been used for years there. Again, can be messy but very good. Be careful around areas where you DO want good metal to metal conductivity.
Old 03-14-2023 | 12:07 AM
sazam's Avatar
Thanks, now looked at Johnnys car - which was flooded - dont know how long it was diving, but it seems the fabric galvanisation is quite ok...
Look at the rotors vs the body...
I think that @Johnny Hotspur GT could say more what was the condition of the body after all this... but even if he will not, from photos looks quite promising....
Not talking here about overall aluminium elements corrosion (oxydation) or the suspension elements corrosion which are not galvanised / they dont care about it.
Old 03-16-2023 | 05:30 AM
DominiquePayne's Avatar
DominiquePayne is infamous around these parts
Keep us updated about your work. I would like to see the outcome. By the way, after reading your post, I came across this website https://letsgradeit.com/review/superiorpapers/ where I can get evaluations of essay writing companies to assist me select the finest one.
DR3ADKN0T
Bentley
10-29-2022 09:22 AM
kongolo
Bentley
11-01-2019 01:16 PM
Dirk989
Bentley
19
02-25-2019 03:33 PM
utkinpol
Northeast
12-25-2009 08:28 PM
raclaims
Bentley
09-06-2009 04:25 PM
Quick Reply: krown - worth doing it?
