gt 2005- emergency / car is dead (electricity)
Old 03-18-2023, 01:58 AM
sazam's Avatar
sazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud of
@Johnny Hotspur GT
thank you - yes I do some edits to have this topic more "complex", instead of having the issues spread across all posts...
reading your statement:
cite: "so yes, redundancy in a way, for when the starter battery is low or dead, the parallel solenoid kicks in and the power from the house battery is tied to the starter battery in parallel, being that you had two different voltages at the front engine area posts,"
this is good track, how to check if eg. the parallel-system works ok or not.
if there is no "turn key left" action, then on start of the car, you should see the voltage drop (checking thru voltmeter) only on the starter battery (the house battery should not have voltage drop)
if there is "turn key left" action, it is expected that the voltage drop (checking thru voltmeter) on the starter battery AND house battery.
right assumptions? asking because together with this issue i have with starting the car overall, I also have suspicion the parallel-system does not work in my car at all, and first I want to confirm it is not working, second I want to pinpoint the problem and wondering how to do it effectively.
wake up, get breakfast and going to fight with the GT monster.
Old 03-18-2023, 08:54 AM
sazam's Avatar
@Johnny Hotspur GT
ok, so I am back from garage... I did the first thing on my list from you and it worked - and from now on i can start the car no matter if i use key to start it or button to start it.
the first thing on my list from you was to put key in the switch and apply ignition on and move it more to right to start it - AND THE CAR STARTED.
i was super surprised, but let the car to run for 3 mins, turned it off
and attempted to start again with button - AND THE CAR STARTED.
Johnny, thank you again very much for your suggestions, looks like the first one was a BINGO number.
Did not took it for a ride yet, just did some more investigations:
a) went thru all fuses again, and no issues + I confirm that the fuse F7 which was blown (vacuum pump) stays now in socket, and is ok (for now)
b) for prevention purposes removed the NAVI, PHONE and TVTUNER fuses (i do not use it anyway) - but did some test on the sockets with amp-meter and they go to ZERO amps when the car goes sleep - do you have any suggestion what else is well-known power consumer and owners have issues , so I can do some preventions too? i heard about broken keyless system and the door-handles consume power all the time (no go to sleep) but like this feature so dont want to remove the fuse
c) wanted to test overall power consumption (get house battery negative connector bridged thru amp-meter) but I failed - the amp-meter was not able to pass the power / cables got hot, car was not feeded) - any suggestions how to do it right? and what measure the car should show when it is opened and active (but not ignition on), when is opened and active (with ignition on / but not started), when is sleepeing?
d) did level UP level DOWN - and it worked, so what I had yesterday disappeared (yesterday there was no reaction to mods to leveling)
e) checked the carpets - dry
f) just as a kind of "just to make sure" checked the mega fuses - if there is voltage behind them, yes there is... but as said "it was just in case" - i assume if car started and all modules responded in vcds, no way there could be a problem on mega fuses
and now go to major topic = this failure:
1. i have no idea what happened , what was the root cause of my problem, what consumed so much power from BOTH batteries
2. i cleared the errors, for now all is clear (as said I did not drive it yet), it only shows on the dash the icon with "!" in a circle-back - I assume i need to drive the car to get rid of it - can you confirm pls?
3. I have no idea about the vacuum pump fuse blown - F7 / driver fuse box (what is the role of this fuse, when there is another one with the same role/name in the boot) - can not say if was it earlier, or maybe vacuum pump had short to ground or smth and it first depleted the batteries (but why ALL of them) and then finally the fuse blown?
4. as said earlier, I got the MIL ON 5km before reaching destination - will see if it will go back after driving - it was related to this error I think:
1 Fault Found:
16627 - Solenoid Valve for Boost Pressure Control (N75)
P0243 - 004 - Malfunction - Intermittent - MIL ON
Readiness: 0000 0000
5. will inform you after test-drive what is the situation
Old 03-19-2023, 03:39 PM
sazam's Avatar
ok, so today I took her on a ride... 70km of test.
1. started without any problems with start-button
2. took few meters (less than 100) to get rid of the icon with "!" in back-circle
3. during the ride, I plugged the voltmeter usb (by baseus) to the cigar plug - showed 13.8v during the ride
4. no MIL ON, and after the ride confirmed the fuse F7 did not blow
5. parked the car, turned off and checked the voltage on the posts - left (A) / alternator = 13.98v, right (B) / starter = 14.53v
decided to do some vcds diagnosis on the car not running, below results
A) here is the scan after finishing my ride, turning off the car, waiting about 10-15mins:
IGNITION ON, ENGINE NOT RUN
Address 01: Engine Labels: 07C-906-018-BEB1.clb
Part No: 07C 906 018 AE
Component: BY-6.0L-TT G ª6485
Revision: 25ÿTT Serial number: 000-00023.07.
Coding: 0000173
Shop #: WSC 00000 000 00000
VCID: 6889ABC6FE6E9E2AA73-513C
VINID: 8D34935460E70454C00850C9246EDF269A
No fault code found.
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 09E 927 760 C HW: GS1 904 1
Component: AG6 09E 6.0L W12TT 1903
Coding: 0001101
Shop #: WSC 00083 000 00000
VCID: 303903A6063E16EABF3-5160
Address 03: ABS Brakes Labels: 3W0-614-517-V1.lbl
Part No: 3W0 614 517 D
Component: ESP 5.7 4WD H01 0021
Coding: 0007878
Shop #: WSC 44605 000 00000
VCID: 363535BEE45A38DAE5F-51F2
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 Q HW: 5WK 470 22
Component: D0 Kessy 6610
Revision: 66105312 Serial number: VWZ3Z0D3257911
Coding: 0155885
VCID: 33330CAAF7282DF2C21-5160
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: 3W0-959-759.clb
Part No: 3W0 959 759 A
Component: CM Seat Pass. 0009
Coding: 0000002
Shop #: WSC 13197 002 1048576
VCID: 47CB487A93B0B1528E9-5160
Address 07: Control Head Labels: 3D0-035-00x-07.lbl
Part No: 3W0 035 007 G
Component: ZAB COCKPIT 0223
Coding: 0400335
5 Faults Found:
00467 - TV Tuner (R78)
004 - No Signal/Communication
01303 - Telephone Transceiver (R36)
01300 - Control Module for Navigation with CD-Rom (J401)
01325 - Control Module for Tire Pressure Monitoring (J502)
00384 - Optical Databus
Address 08: Auto HVAC Labels: 3W7-907-040.clb
Part No: 3W0 907 040 B
Component: Climatronic BY614 0030
Coding: 0000001
Address 09: Cent. Elect. Labels: 3D0-937-049-V1.clb
Part No: 3D0 937 049 H
Component: STG.Bordnetz 5101
Coding: 0000107
VCID: 2F3B00DA1B000912A69-5160
Address 11: Engine II Labels: 07C-906-018-BEB2.clb
Revision: 31ÿTT Serial number: 000-00023.07.
Coding: 0000173
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 E
Component: 0P Airbag 8.4E+ H10 0936
Coding: 0012368
VCID: 2517E2F249FC43425C5-5160
Address 16: Steering wheel Labels: 3D0-953-549.lbl
Part No: 3D0 953 549 D
Component: Lenksäulenmodul 3401
Coding: 0000012
VCID: 2E051DDE1C0A001AADF-5160
Address 17: Instruments Labels: 3Wx-920-xxx-17.lbl
Part No: 3W0 920 840 P
Component: KOMBIINSTRUMENT RB8 0402
Coding: 0021100
VCID: 41DF5662BD948F6240D-5160
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70B9C3A6C6BE56EAFF3-5160
Address 34: Level Control Labels: 3D0-907-553-V1.clb
Part No: 3W0 907 553
Component: LUFTFDR.-CDC- 3C1V0 7014
Coding: 0015500
Shop #: WSC 44605 003 1048576
VCID: 77ABF8BAA3D001D23E9-5160
Address 36: Seat Mem. Drvr Labels: 3W0-959-759.clb
Part No: 3W0 959 760 A
Component: CM Seat Driver 0008
Coding: 0000002
VCID: 3FDB509ACB60F992369-5160
1 Fault Found:
01976 - Seat Depth Adjustment Motor (V234)
005 - No or Incorrect Basic Setting / Adaptation
Address 38: Roof Electronics Labels: None
Part No: 3W0 907 135 C
Component: Dachmodul 0703
Coding: 0000157
VCID: 363535BEE45A38DAE5F-5160
Address 46: Central Conv. Labels: 3D0-959-933.clb
Part No: 3D0 959 933 F
Component: 1Y HSG 0101
Coding: 0000032
VCID: 33330CAAF7282DF2C21-4B00
Subsystem 1 - Part No: 3W1 959 701
Component: Tuersteuergeraet FS 0702
Subsystem 2 - Part No: 3W1 959 702
Component: Tuersteuergeraet BF 0702
Subsystem 3 - Part No: 3W3 959 703 C
Component: Tuersteuergeraet HL 0702
Subsystem 4 - Part No: 3W3 959 704
Component: Tuersteuergeraet HR 0702
Subsystem 5 - Part No: 7L0 907 719
Component: Neigungssensor 0020
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 3W0 035 456 C
Component: 12K-AUDIOVERST 4121
VCID: 34310FB6F2262ACADBB-5160
Address 53: Parking Brake Labels: 3W0-907-801.clb
Part No SW: 3W0 907 801 B HW: 3W0 907 801 B
Component: EPB BC6HX23 HC6 X230
Coding: 0022413
VCID: 353732B2F95C33C2EC5-5160
Address 54: Rear Spoiler Labels: 1C0-959-733.lbl
Part No: 1C0 959 733 H
Component: Heckspoiler 0002
VCID: 303903A6033E16EABF3-51F2
Address 68: Wiper Electr. Labels: 3Wx-955-023.clb
Part No: 3W1 955 023 C
Component: WischeX
Shop #: WSC 00000 725 65552
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 C
Component: Batteriemanagement 2700
VCID: 2313FCEA47C8BD72321-5160
Address 76: Park Assist Labels: 3W0-919-283-V1.clb
Part No: 3W0 919 283
Component: 02 Einparkhilfe 0203
VCID: 7AADE18E90C21CBA417-5160
End----(Elapsed Time: 08:06, VBatt start/end: 12.1V/12.1V. VIgn 0.0V)------
I assume the faults are just because I removed fuses for navi, phone and tvtuner and tpms.
The optical bus error is because of navi no fuse (I assume? pls correct me if I am wrong).
decided to start the engine, and...
having the key in the ignition switch
having ignition on
having the ross-tech connected
ISSUE!!! -> I decided to press START-BUTTON, and... AGAIN, the car did not start,
I had to start the engine by moving the key max to right - car started - is this intentional? if I have key in the switch and having communication with OBD, then I am not able to start with button? I dont think so...
B) scan done when car was running, after starting it by switching key max to right (earlier unsuccessful start by START-BUTTON)
IGNITION ON, CAR STARTED AND RUNS
Coding: 0001101
Coding: 0007878
Coding: 0155885
Component: ELV XXXX
2 Faults Found:
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
011 - Open Circuit
00184 - Control Circuit for Engine Start/Stop Switch
008 - Implausible Signal
Coding: 0000002
Coding: 0400335
5 Faults Found:
Coding: 0000001
Coding: 0000107
Coding: 0000173
VCID: 6889ABC6FE6E9E2AA73-5160
Coding: 0012368
Coding: 0000012
Coding: 0021100
1 Fault Found:
Coding: 0000006
3 Faults Found:
Coding: 0015500
Coding: 0000002
1 Fault Found:
Coding: 0000157
Coding: 0000032
Coding: 0022413
Component: WischeX
End----(Elapsed Time: 04:40, VBatt start/end: 13.6V/13.6V. VIgn 0.0V)------
looks like when the car is running, can gateway and instrumens module realised there is problem with navi, phone etc. - they did not complain when the car was not running (see scan A)
ISSUE -> but what is interesting - addr5, shows errors connected to my fail with the starting the car with START-BUTTON. any suggestions what is the problem, if there is a problem?
2 Faults Found:
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136) 011 - Open Circuit
00184 - Control Circuit for Engine Start/Stop Switch 008 - Implausible Signal
I did also some measurements during the car run, I dont see issues, but I dont have experience - pls take a look and report if anything not right
MEASURES:
Engine
16:24:07
520 /min Engine Speed (G28)
96.0°C Coolant Temperature (G62)
15.0 % Engine Load
2.53 g/s Mass Air Flow Sensor
13.370 V Battery Voltage (Terminal 30)
66.0°C Intake Air Temperature (G42)
Battery Charger
16:26:50
13.66 V Term 15 (Ignition) (start relevant)
13.73 V Terminal 30 (start relevant)
13.80 V Terminal 30 (Comfort battery)
14.60 V Terminal 30 (starter battery)
0.0 A Current Term 15 (Ignition)
0.0 A Current Term 30 (Battery)
22.0°C Battery compartment temperature
24.0°C Internal battery temperature
Term 15 On Digital input Term 15 (Ignition)
512 /min Engine Speed
96.0°C Temperature of generator
bottom line:
1. what is wrong with starting the car with START-BUTTON? see both addr5 errors, problem with starting via button again as described?
2. can you confirm the alternator gives right voltage to power up the batteries? its temp almost 100C is ok?
3. i saw on the real-time logging that the rpms (engine speed) fluctuates 520-544, it is not visible on the dash arrow, but vcds shows that fluctuations - minor,? or smth to take a look deeper?
4. still dont have any clue what was the reason of the battery depletion in 20hours and initial issues with starting the car etc
5. hope tomorrow i will get the car alive, with batteries powered - any guidance how to do the power stealing test right?
6. the blowed fuse mistery not solved (not sure why and when it blowed, and if this has anything to do with the battery depletion)
7. not known the root cause of this error which showed 3 days ago, MIL ON , 5kms prior to car-stop and battery depletion - 1 Fault Found: 16627 - Solenoid Valve for Boost Pressure Control (N75) P0243 - 004 - Malfunction - Intermittent - MIL ON Readiness: 0000 0000
8. and if anyone could guide me how to do the deep diagnosis of the emergency battery parallel powering - I suspect this feature does not work for me at all (do not hear any click of the relays or smth - silence).
Old 03-19-2023, 03:52 PM
Shaqovic's Avatar
Shaqovic is infamous around these parts
Coding: 0000173
Coding: 0001101
Coding: 0007878
Coding: 0155885
Component: ELV XXXX
Coding: 0000002
Coding: 0400335
5 Faults Found:
Coding: 0000001
Coding: 0000107
Coding: 0000173
Coding: 0012368
Coding: 0000012
Coding: 0021100
Coding: 0000006
Coding: 0015500
Coding: 0000002
1 Fault Found:
Coding: 0000157
Coding: 0000032
Coding: 0022413
Component: WischeX
having ignition on
Coding: 0001101
Coding: 0007878
Coding: 0155885
Component: ELV XXXX
2 Faults Found:
011 - Open Circuit
Coding: 0000002
Coding: 0400335
5 Faults Found:
Coding: 0000001
Coding: 0000107
Coding: 0000173
Coding: 0012368
Coding: 0000012
Coding: 0021100
1 Fault Found:
Coding: 0000006
3 Faults Found:
Coding: 0015500
Coding: 0000002
1 Fault Found:
Coding: 0000157
Coding: 0000032
Coding: 0022413
Component: WischeX
2 Faults Found:
MEASURES:
Address 01: Engine (07C 906 018 AE)16:24:07
15.0 % Engine Load
Address 71: Battery Charger (3D0 915 181 C)
16:26:50
bottom line:
7. not known the root cause of this error which showed 3 days ago, MIL ON , 5kms prior to car-stop and next battery depletion - 1 Fault Found: 16627 - Solenoid Valve for Boost Pressure Control (N75) P0243 - 004 - Malfunction - Intermittent - MIL ON Readiness: 0000 0000
the car it self is quite complicated to understand fully, what I can tell you is to charge the batteries full, put back all fuses and test drive for 30 minutes, make sure all fuses are installed and your passenger door lock is looked all the time(orange color on icon) because this lock is a common fault and it keeps drawing battery
Garage the car, lock it and try it after 24hrs, if batteries are flat, I would suggest to check if they keep power before I would start to investigate further more, you can do this by charging them full out of the car and leave them out for 24hrs and test them with voltmeter and compare after full charged and passed 24hrs.
hope I did fine explaining what I went throu 😞
Old 03-24-2023, 02:58 PM
sazam's Avatar
@Shaqovic thank you - yes, did battery charging, then disconnected the charger, and checked 24hrs later - this time, I was able to start the car without any issues...
what I see is that no matter how long i will keep the house battery on charging, it is 12.4V, and when connecting to vcds - it shows 12.2V.
maybe this battery is not in so good condition as the battery shop says - they did the test, and battery is labelled in their tool as "OK".
I have new info - I had a planned travel so i took the opportunity to check what is going on - was risky, I was affraid the car will stop working, but luckily it went ok...
350km - one direction, mostly highways - 120km/h, 140km/h - few moments with boosts to 180-200, nothing more
50km - city traffic
350km - go back, again highways - 120-140km/h
so I made about 800kms
there was raining - so used wipers - wipers worked as expected, timers, washers, mode with rain sensor - saying this as a comment to the listed below...
when I run above 140 - automatically rear spoiler was deployed, and then when i went below 100 (i think) it automatically was closed
i did not do any manual on/off of the rear spoiler
1. car worked well, was able to start/stop etc - no issues, running fast as rocket, etc
2. during travel - 13.6-13.8v on my cigar-plug usb voltmeter
3. but AGAIN, what a coincidence, 5km prior to reaching back my home, MIL ON fired
immediately after parking in the garage - i checked thru vcds... catch some errors:
1 Fault Found:
Readiness: 0000 1000
2 Faults Found:
011 - Open Circuit
008 - Implausible Signal - Intermittent
1 Fault Found:
01509 - Spoiler not Extended at Speed Exceeding Warning Threshold
35-10 - - - Intermittent
1 Fault Found:
00003 - Control Module
014 - Defective
After clearing all DTCs, only this one stays:
1 Fault Found:
011 - Open Circuit
Anyone can guide me to pinpoint the root cause of the problems?
Old 04-02-2023, 01:42 AM
tmobileguy's Avatar
tmobileguy is infamous around these parts
Originally Posted by Samhain
Wow - bummer dude.
Please keep us posted every step of the way.
Really insightful and ground breaking stuff. Talk about a worthless reply.
Old 04-02-2023, 11:50 AM
Johnny Hotspur GT's Avatar
Administrator
I couldn't agree more...
That's why it's been deleted.
He has been trolling Sazam for a while, I figured I'd let the two of them work it out, but it ends today !
Johnny
crusher
Bentley
14
10-26-2023 02:45 AM
V12diablo
Bentley
28
04-03-2022 03:45 PM
fishbone
Bentley
08-18-2020 07:13 PM
Wyo
Bentley
14
03-17-2018 05:32 PM
Quick Reply: gt 2005- emergency / car is dead (electricity)
