gt 2005- emergency / car is dead (electricity)
guys - pls help - i drove yesterday to another city - today i went to my car in the underhotel garage and my car is dead - no power total zero.
i have the hw with me - multimeter and vcds and charger - so at least want to try smth
problem is there is a place under the hood where i can put charger but on the left i have only 4v on the right i have 8v
connected charger to a bolt with 8v - no effects - car is not waking up
i dont know if i should connect to the 4v bolt?
anyone knows the diff? one is for left another for right battery?
connected rosstech and did interface test and have no power on k-lines and it shows 4.42v
it looks like the left bolt is for the accessory battery and the right one is for starter battery.
i opened the boot lid thru emergency handle on back of the seat and voltmeter the both batteries - the left one (accessory) has only 4.4v
plugged charger to it now directly
now - smth is really worrying me - when i opened the hood i charged thru the right bolt - so i feeded the starter battrty and it was ok
but when i came to conclusion the the left bolt is for accessory battery i connected positive to the left bolt (4.4v) and the clamp started sparkling - i left the negative in the same place where it was earlier.
what is going on? i hope i did not fried anything
i will left the battery under charger whole night, will see in the morning.
question - what could happen that i drove the car without any problems, parked in the garage, closed the car as always and after one night smth consumed all the energy (as said on the left bolt I had 4v, on the right bolt I had 8v)
anyone from you experienced that thing?
How old are the batteries? If they test good you need to look at the charging system and cables. Bad alternator or voltage regulator? In 1975 I drove a brand new Mercury Monarch off the dealer's lot and had to be towed in an hour later due to a bad voltage regulator.
starter - brand new, accessory - 1.5year.
accessory tested with tools on the battery shop - perfect condition.
i dont think it is alternator issue cause the car whole travel was ok - and electricity was there when i turned off the car - after 24 hours the batteries were depleted.
ideas what could consume the whole energy when it was sleeping?
john - what supports what in emergency on? accessory should help starter battery to feed starter motoror starter is heping accessory to feed electronics
first to do I to check for any leak and you can start with pulling fuses and then use circuit tester screwdriver, I find it more powerful than digitals
also remember to check for alternator leak
hope this was helpful
@Shaqovic sure your info is super helpful, any ideas are welcome.
Guys,
let me report all my actions in order (and situation description).
before the problem:
so I started the recovery:
day1
day2
now where I am:
so I listed you the whole detailed sequence of actions
anyone can help me with that?
ps. i tried 2 more times with the START button, but exactly the same result - lights go off, on infotainment display eg. the AC is presented but looks like disabled
AND i tried also the key switch LEFT and RIGHT, but I suspect I have this not working at all - I dont hear any click in the rear on this operation and this is how I have it from the beginning I have the car, this is nothing new
<SCAN1> the very first after charging batteries, when finally vcds told that OBD / K lines connection is ok
Friday,17,March,2023,09:16:03:54358
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.0.0 (x64) HEX-V2 CB: 0.4631.4
Data version: 20230228 DS346.1
Dealer/Shop Name: MY_GARAGE
Workshop Code: 678 12345 099999
VIN: SCBCE63W15C014288 License Plate:
Mileage: 213070km-132395mi Repair Order: 17.03.2023_DEAD
Chassis Type: 3W (3W - Bentley Continental (2004 > 2007))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
VIN: SCBCE63W15C014288 Mileage: 213070km-132395miles
Address 01: Engine Labels: 07C-906-018-BEB1.clb
Part No: 07C 906 018 AE
Component: BY-6.0L-TT G ™6485
Revision: 25ˇTT Serial number: 000-00023.07.
Coding: 0000173
Shop #: WSC 00000 000 00000
VCID: 6889ABC6FE6E9E2AA73-513C
VINID: 8D34935460E70454C00850C9246EDF269A
1 Fault Found:
16627 - Solenoid Valve for Boost Pressure Control (N75)
P0243 - 004 - Malfunction - Intermittent - MIL ON
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 09E 927 760 C HW: GS1 904 1
Component: AG6 09E 6.0L W12TT 1903
Coding: 0001101
Shop #: WSC 00083 000 00000
VCID: 303903A6063E16EABF3-5160
No fault code found.
Address 03: ABS Brakes Labels: 3W0-614-517-V1.lbl
Part No: 3W0 614 517 D
Component: ESP 5.7 4WD H01 0021
Coding: 0007878
Shop #: WSC 44605 000 00000
VCID: 363535BEE45A38DAE5F-51F2
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 Q HW: 5WK 470 22
Component: D0 Kessy 6610
Revision: 66105312 Serial number: VWZ3Z0D3257911
Coding: 0155885
VCID: 33330CAAF7282DF2C21-5160
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
4 Faults Found:
00184 - Control Circuit for Engine Start/Stop Switch
008 - Implausible Signal - Intermittent
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
011 - Open Circuit
00668 - Supply Voltage Terminal 30
009 - Open or Short to Ground - Intermittent
00087 - Terminal 30 for Starting Relevant Consumers
Address 06: Seat Mem. Pass Labels: 3W0-959-759.clb
Part No: 3W0 959 759 A
Component: CM Seat Pass. 0009
Coding: 0000002
Shop #: WSC 13197 002 1048576
VCID: 47CB487A93B0B1528E9-5160
3 Faults Found:
002 - Lower Limit Exceeded - Intermittent
02569 - Control Module for Massage (J740)
012 - Electrical Fault in Circuit - Intermittent
Address 07: Control Head Labels: 3D0-035-00x-07.lbl
Part No: 3W0 035 007 G
Component: ZAB COCKPIT 0223
Coding: 0400335
2 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Address 08: Auto HVAC Labels: 3W7-907-040.clb
Part No: 3W0 907 040 B
Component: Climatronic BY614 0030
Coding: 0000001
Address 09: Cent. Elect. Labels: 3D0-937-049-V1.clb
Part No: 3D0 937 049 H
Component: STG.Bordnetz 5101
Coding: 0000107
VCID: 2F3B00DA1B000912A69-5160
3 Faults Found:
00907 - Intervention load Management
000 - -
01755 - Switch for Parking Lights (E1)
01335 - Drivers Seat/Mirror Position Control Module (J543)
004 - No Signal/Communication - Intermittent
Address 11: Engine II Labels: 07C-906-018-BEB2.clb
Revision: 31ˇTT Serial number: 000-00023.07.
Coding: 0000173
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 E
Component: 0P Airbag 8.4E+ H10 0936
Coding: 0012368
VCID: 2517E2F249FC43425C5-5160
Address 16: Steering wheel Labels: 3D0-953-549.lbl
Part No: 3D0 953 549 D
Component: Lenks‰ulenmodul 3401
Coding: 0000012
VCID: 2E051DDE1C0A001AADF-5160
1 Fault Found:
00532 - Supply Voltage B+
Address 17: Instruments Labels: 3Wx-920-xxx-17.lbl
Part No: 3W0 920 840 P
Component: KOMBIINSTRUMENT RB8 0402
Coding: 0021100
VCID: 41DF5662BD948F6240D-5160
10 Faults Found:
00457 - Central Electronics Control Module / BCM (J519)
00466 - Control Module for Steering Column Electronics (J527)
00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
01320 - Control Module for Climatronic (J255)
01330 - Central Control Module for Central Convenience (J393)
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J389)
01305 - Databus for Infotainment
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70B9C3A6C6BE56EAFF3-5160
15 Faults Found:
00461 - Control Module for Seat Memory; Passenger (J521)
00908 - Control Module for Wiper Motor
01308 - Control Module for Roof Electronics (J528)
01327 - Control Module for Parking Aid (J446)
Address 34: Level Control Labels: 3D0-907-553-V1.clb
Part No: 3W0 907 553
Component: LUFTFDR.-CDC- 3C1V0 7014
Coding: 0015500
Shop #: WSC 44605 003 1048576
VCID: 77ABF8BAA3D001D23E9-5160
2 Faults Found:
01598 - Drive Battery Voltage
00778 - Steering Angle Sensor (G85)
Address 36: Seat Mem. Drvr Labels: 3W0-959-759.clb
Part No: 3W0 959 760 A
Component: CM Seat Driver 0008
Coding: 0000002
VCID: 3FDB509ACB60F992369-5160
4 Faults Found:
01976 - Seat Depth Adjustment Motor (V234)
005 - No or Incorrect Basic Setting / Adaptation
Address 37: Navigation Labels: None
Part No: 3W0 919 887 B
Component: NAVIGATION 0168
Coding: 0400000
VCID: 46D5457E94BAA85A75F-5160
1 Fault Found:
Address 38: Roof Electronics Labels: None
Part No: 3W0 907 135 C
Component: Dachmodul 0703
Coding: 0000157
VCID: 363535BEE45A38DAE5F-5160
1 Fault Found:
00926 - Terminal 30
Address 46: Central Conv. Labels: 3D0-959-933.clb
Part No: 3D0 959 933 F
Component: 1Y HSG 0101
Coding: 0000032
VCID: 33330CAAF7282DF2C21-4B00
Subsystem 1 - Part No: 3W1 959 701
Component: Tuersteuergeraet FS 0702
Subsystem 2 - Part No: 3W1 959 702
Component: Tuersteuergeraet BF 0702
Subsystem 3 - Part No: 3W3 959 703 C
Component: Tuersteuergeraet HL 0702
Subsystem 4 - Part No: 3W3 959 704
Component: Tuersteuergeraet HR 0702
Subsystem 5 - Part No: 7L0 907 719
Component: Neigungssensor 0020
11 Faults Found:
00927 - Terminal 30 (Right)
011 - Open Circuit - Intermittent
01516 - Terminal 30; Left
00926 - Terminal 30
01134 - Alarm Horn (H12)
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 3W0 035 456 C
Component: 12K-AUDIOVERST 4121
VCID: 34310FB6F2262ACADBB-5160
1 Fault Found:
Address 53: Parking Brake Labels: 3W0-907-801.clb
Part No SW: 3W0 907 801 B HW: 3W0 907 801 B
Component: EPB BC6HX23 HC6 X230
Coding: 0022413
VCID: 353732B2F95C33C2EC5-5160
Address 54: Rear Spoiler Labels: 1C0-959-733.lbl
Part No: 1C0 959 733 H
Component: Heckspoiler 0002
VCID: 303903A6033E16EABF3-51F2
Address 57: TV Tuner Labels: 3D0-919-146.lbl
Part No: 3D0 919 146
Component: TV Tuner H07 1205
Coding: 0000010
VCID: 6597A2F2097C83429C5-5160
Address 68: Wiper Electr. Labels: 3Wx-955-023.clb
Part No: 3W1 955 023 C
Component: WischeX
Shop #: WSC 00000 725 65552
2 Faults Found:
00459 - Control Module for Display and Input; Front (J523)
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 C
Component: Batteriemanagement 2700
VCID: 2313FCEA47C8BD72321-5160
Address 76: Park Assist Labels: 3W0-919-283-V1.clb
Part No: 3W0 919 283
Component: 02 Einparkhilfe 0203
VCID: 7AADE18E90C21CBA417-5160
Address 77: Telephone Labels: None
Part No: 3W0 035 729 K
Component: Telefon 0252
1 Fault Found:
End----(Elapsed Time: 07:06, VBatt start/end: 12.3V/12.3V. VIgn 0.0V)------
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 05: DTCs cleared
Address 06: DTCs cleared
Address 07: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 11: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 34: DTCs cleared
Address 36: DTCs cleared
Address 37: DTCs cleared
Address 38: DTCs cleared
Address 46: DTCs cleared
Address 47: DTCs cleared
Address 53: DTCs cleared
Address 54: DTCs cleared
Address 57: DTCs cleared
Address 68: DTCs cleared
Address 71: DTCs cleared
Address 76: DTCs cleared
Address 77: DTCs cleared
<SCAN2> the rescan after clearing all dtc errors
Coding: 0000173
Readiness: 0110 1101
Coding: 0001101
Coding: 0007878
1 Fault Found:
000 - -
Coding: 0155885
Component: ELV XXXX
Coding: 0000002
Coding: 0400335
1 Fault Found:
Coding: 0000001
Coding: 0000107
Coding: 0000173
Coding: 0012368
Coding: 0000012
Coding: 0021100
Coding: 0000006
Coding: 0015500
1 Fault Found:
Coding: 0000002
1 Fault Found:
Coding: 0400000
Coding: 0000157
Coding: 0000032
Coding: 0000010
Component: WischeX
End----(Elapsed Time: 08:07, VBatt start/end: 12.0V/12.0V. VIgn 0.0V)------
<SCAN3> the rescan done after unsuccessful START of the car (pressed START button, no effect, light down)
Friday,17,March,2023,11:47:43:54358
Mileage: 213070km-132395mi Repair Order: 2ND
Coding: 0000173
Coding: 0001101
Coding: 0007878
1 Fault Found:
000 - -
Coding: 0155885
Component: ELV XXXX
2 Faults Found:
011 - Open Circuit
Coding: 0000002
Coding: 0400335
1 Fault Found:
Coding: 0000001
Coding: 0000107
Coding: 0000173
Coding: 0012368
Coding: 0000012
Coding: 0021100
Coding: 0000006
Coding: 0015500
1 Fault Found:
Coding: 0000002
1 Fault Found:
Coding: 0400000
Coding: 0000157
Coding: 0000032
Coding: 0022413
Coding: 0000010
End----(Elapsed Time: 06:39, VBatt start/end: 11.9V/11.8V. VIgn 0.0V)------
Guys,
before the problem:
- i drove about 100km , everything was fine, the ONLY issue (however maybe this is an important thing) about 5km before reaching the destination I got MIL on - I decided to continue the travel, cause I was very close to destination, and there was no communication "GO TO SERVICE" or "STOP THE CAR" or smth like this
- I reached the destination and did not do any scans - I decided to leave it, and look at it the next day, Ive just turn off the car, closed it thru keyless and saw the red diode on the doors that alarm is armed, and went away.
- next day, after about 20hour from stopping the car I went to the garage and tried remotely open the car thru RC but there was no reaction;
- when came closer to the car, I saw that the diode on the doors is not blinking, realised that battery depletion happened (Ive opened door thru keys, infotainment did not start, Ive put the key into ignition, no reaction at all etc)
day1
- opened the hood, and checked the voltage on the connectors near plenum chamber - on left (A) I got 4v, on right (B) I got 8v - see PICTURES
- ive connected vcds but vcds-connection test said K1 and K2 lines are not powered - sounds like obvious if I have so depleted batteries, so i gave up
- Ive connected charger to right (looking on the engine from front point of view) bolt/connector (B) - no strange reactions - after 20mins, i checked what is the voltage and voltage went up to 11v, but still no effects inside the car, no lights on, no ignition on etc
- so i decided to connect charge to the left bolt (looking on the engine from front point of view) (A) - and here I got strange reaction - the clamp connected started to sparkling every second so i quickly disconnected it
- i realised that left (connector A) may be for accessory battery, right (connector B) may be for starter battery - so having this strange behaviour I did not want to risk anything and I decided to do emerg opening of the boot - did what needed, got into the boot
- i measured the voltage - acc battery was 4v, starter battery was 11v now
- I connected the charger directly to left battery - and left it for whole rest of day/night till today morning
day2
- today I confirmed the voltage on the left battery is 12.45, on right is 12.8 but anyway I decided to order tow-truck and they transported my car to my home-town
- from the noon I am playing with the car with no success - here is the story
- after charging, car wake up - lights visible, able to open / close doors thru keyless, when putting key into switch, the steering wheel is unlocked, when switched ignition on, all the light on the dash shows up, infotainment says "Bentley WELCOME" and pairs the key, hvac blower runs, looks like everything ok
- the only issue I got -that having ignition on - I clicked the suspension leveling and got no reaction, just does not go up or down, says that leveling system can not run or smth (on the dash) but it was one time, then later when the scans were done and errors cleared, there is no leveling issue message on the dash, but the problem (or maybe it is not a problem if I have car off and only ignition on) is that when I move to low or to high, there is no reaction, it always stays on low
- so I did not attempt to start the car yet, first wanted to check errors - connected vcds, vcds-connection test run OK, K lines powered all OK.
- did the FIRST run of full scanning - and got tons of errors as below <SCAN1>
- cleared all errors an rerun the scan - see below <SCAN2>
- still did not started the car, before that I decided to go thru all fuses with continuity check (beeper on voltmeter)
- I found out that fuse no 7 in the driver side fuse box was blown - it is 15A vacuum pump - now question:
- is it possible it was blown for longer period of time, or this is so important fuse that if blown I would not run / drive the car
- i am asking to correlate problems (when actually this could occur)
- I switched the fuse, is not blowing, it stays ok now (still I dont run the car)
- the rest of the fuses went ok with continuity check - i tested driver side box, plenum chamber and the fuses over the accessory battery
- so now i decided to try the START button, I switched the ignition on - all lights went on on the instruments/dash - nice car picture with opened hood, boot and driver doors, on the display, looks all ok, pressed START and all lights on the instruments go down, and on the instrument display the car picture appear but only car and odometer is visible, the PRNDS disappear and the leveling icon dissapear, the infotainment (eg. having it on AC display) also goes down - but still see graphics but the settings go away - see the PICTURES
ignition on, not yet pressed START button:
ignition on, after pressing START button, lights go off, graphics looks like this:
- and car does not start, turned ignition off and on, and lights go back etc - again looks ok, i can repeat this step but no run, still the same effects as in p.12
- i made another vcds scan after the unsuccessful START - and there is the result - <SCAN3>
- what i did more, was to disconnect the both batteries - and I waited 30mins, connected back, did the vcds scan, no new issues, pressed START and exactly the same behaviour,
now where I am:
- car does not start, with the symptoms as above
- i noticed in first scan <SCAN1> an evidence error of the MIL on case - see this
1 Fault Found:
- but now this error does not reoccur in SCAN2 or 3 - assume it may come back when the car will run
- no idea coincidence of the blowed fuse 7
- no idea of any coincidence of the sparkling clamp on left connector
- BTW: TPMS error, Driver Seats Adjustment error is something I got from the begining of owning this car.
Coding: 0000173
1 Fault Found:
Coding: 0001101
Coding: 0007878
1 Fault Found:
000 - -
Coding: 0155885
Component: ELV XXXX
4 Faults Found:
011 - Open Circuit
Coding: 0000002
3 Faults Found:
Coding: 0400335
2 Faults Found:
Coding: 0000001
Coding: 0000107
3 Faults Found:
000 - -
Coding: 0000173
Coding: 0012368
Coding: 0000012
1 Fault Found:
Coding: 0021100
10 Faults Found:
Coding: 0000006
15 Faults Found:
Coding: 0015500
2 Faults Found:
Coding: 0000002
4 Faults Found:
Coding: 0400000
1 Fault Found:
Coding: 0000157
1 Fault Found:
00926 - Terminal 30
Coding: 0000032
11 Faults Found:
00926 - Terminal 30
1 Fault Found:
Coding: 0022413
Coding: 0000010
Component: WischeX
2 Faults Found:
1 Fault Found:
Coding: 0000173
Coding: 0001101
Coding: 0007878
1 Fault Found:
000 - -
Coding: 0155885
Component: ELV XXXX
Coding: 0000002
Coding: 0400335
1 Fault Found:
Coding: 0000001
Coding: 0000107
Coding: 0000173
Coding: 0012368
Coding: 0000012
Coding: 0021100
Coding: 0000006
Coding: 0015500
1 Fault Found:
Coding: 0000002
1 Fault Found:
Coding: 0400000
Coding: 0000157
Coding: 0000032
Coding: 0000010
Component: WischeX
Coding: 0000173
Coding: 0001101
Coding: 0007878
1 Fault Found:
000 - -
Coding: 0155885
Component: ELV XXXX
2 Faults Found:
011 - Open Circuit
Coding: 0000002
Coding: 0400335
1 Fault Found:
Coding: 0000001
Coding: 0000107
Coding: 0000173
Coding: 0012368
Coding: 0000012
Coding: 0021100
Coding: 0000006
Coding: 0015500
1 Fault Found:
Coding: 0000002
1 Fault Found:
Coding: 0400000
Coding: 0000157
Coding: 0000032
Coding: 0022413
Coding: 0000010
Hello @sazam ,
As far as the 2 posts under the hood, facing the engine as you said, the left post is the connection for the alternator cable, the right side post is the connection for the starter cable to feed the starter, on the back side of this junction point you will see 3 post, 2 on the left, both on the house battery circuit tying in the alternator, 1 on the right to the starter battery feeding the starter, so your connection to either one is fine, you extra spark activity is most likely because the left house battery was lower in charge than the starter battery, OR, something is on consuming power, therefore the extra arc, OR, your alternator itself may be at fault, so, being that the engine has not ran now for a while, it will be nice and cold, so with all the batteries hooked up and fully charged, reach under the vehicle and get your hands on the alternator itself to see if it is warm to the touch, meaning, warmer than any other part of the engine, if the alternator is warm or hot, it has stuck in the on position, and therefore has turned into a motor therefore draining the batteries.
I would like to know that when you charged the left (house) battery, did the right side starter battery automatically charge, or did you have to swap your charger over to it ?
As to the push button start, as the 2005 didn't come with it in North America, but I believe it did in your part of the world, please confirm that your PBS is factory, and while on the PBS, by chance did you loosen the connection on it while working on the cigar lighter, ALSO, does the starter crank when you turn the key in the ignition all the way to the right for start ?
Your batteries are still low after your charging, they should be above 13.2 volts, I see 11.8 at the end of a scan...
To bypass all items to test the starter itself, be sure both batteries are fully charged, then remove the cover of the 433 relay in the boot as pictured, and push the bottom up as shown, that is the starter relay, the engine should turn over, but not start and run on if the ignition is off.
Be sure to check all of the mega fuses on the left side house battery, as your terminal 30 has issues, check the flat blade fuses on top of the right side starter battery also.
More to come.
Very busy with work phone calls.
Johnny
More to come.
Johnny
hope i did not hurt anything by the wrongly assuming the left-connector is for house (i called it accessory) battery
right - i confirm, i was able to charge starter battery thru the right connector
i will go and check the alternator if it is hot
regarding the automatic charging of right battery, when left was charged,
i dont think so...
when first I plugged the clamp to the right connector the starter battery was charged and nothing changed on the left connector (which as you said is wired with the house battery)
then when I reached to the boot, I directly connected the house battery, and I did not notice the starter battery was charged automatically
so early in the morning when I visit the garage/car i swapped my charger to the starter battery
finally i reached 12.8 on starter and 12.4 on house battery
yes I have european model, swiss, with PBS feature from factory
I could loose smth, but i played this cigar stuff 1 day before this 100k tragic travel, and I started the car many times from the time I played with cigar with no issue
but will double check, however - still there is strange reaction of going light down when pushing it so there is connection
regarding crank on turning ignition to right - you mean to try to start the car by turning the key max to the right or just when turning the key to the ON position?
Ive never tried to start the car with a key turn, I always used button - will check it if I understood you correctly (as above)
yes, my batteries now are loosing power very fast, actually the house battery, I connected the charger to it when i was playing with VCDS,
and anyway, having all the time VCDS in use and did few full scans in a row, then played directly with scans on addr 05, and other addresses which still had errors
suddenly I got yet another error - but pls correct me if I am wrong - this may be actually related to fact that i loaded the vcds too much and consumed too much battery during this all scanning:
Control Module Part Number: 3D0 937 049 H
Component and/or Version: STG.Bordnetz 5101
Software Coding: 0000107
Work Shop Code: WSC 00083 000 00000
1 Fault Found:
000 - -
when saw this, I went to the addr71 - "battery charger" - and dumped some measures:
Address 71: Battery Charger (3D0 915 181 C)
17:36:07
11.35 V Term 15 (Ignition) (start relevant)
11.35 V Terminal 30 (start relevant)
11.42 V Terminal 30 (Comfort battery)
12.86 V Terminal 30 (starter battery)
0.0 A Current Term 15 (Ignition)
0.0 A Current Term 30 (Battery)
14.0°C Battery compartment temperature
14.0°C Internal battery temperature
Term 15 On Digital input Term 15 (Ignition)
Term 50 Off Digital input Term 50 (Starter)
ON Digital input Key In
11.0°C Temperature of generator
btw - is generator = alternator?
if yes - the computer tells it is only 11 C degree
433 - i dont see the picture / forum server issue or smth on my side, will try to reboot etc my comp
mega fuses - I assume that if I will check voltage after the fuse it will be a right test yeah?
thanks John for reactions!!!!
i dont think so...
1 Fault Found:
000 - -
17:36:07
@Johnny Hotspur GT - thx! i restarted the computer with other ISP, looks like my current ISP has some issues and the graphical content served by AWS is not going thru... now I see the pictures, will do the stuff you suggest.
ps. I also added the pictures on my post.
regarding this:
i will do the trick, but you suggest to just try it with ignition off, or try it with ignition on?
for this:
i just check the continuity of this blade-fuses
btw - the above is the starter battery fuse box, with starter motor fuse
and below we have also starter motor fuse, but here is on the house battery?
redundancy?
regarding this:
for this:
redundancy?
Hello @sazam ,
You can press the relay with the ignition either on or off, I just want to hear that the starter spins, and that it or it's solenoid is not the issue.
As far as the mega fuses, the house battery is on the left facing the trunk, the starter battery is on the right, the 300 amp mega fuse on the house battery bus bar is NOT the starter power cable per se, that cable runs to the parallel solenoid above the starter battery, as I am typing this I guess you have edited your comments, so yes, redundancy in a way, for when the starter battery is low or dead, the parallel solenoid kicks in and the power from the house battery is tied to the starter battery in parallel, being that you had two different voltages at the front engine area posts, I believe that your pyrotechnic positive cable on the starter battery is good, but verify that you have power on both sides of the pyro joint.
Johnny
Johnny
