2014 Bentley Flying Spur Rear Entertainment not working.
Old 03-22-2023 | 06:37 AM
Dgeedhar's Avatar
Dgeedhar is infamous around these parts
Hi everyone. I recently purchased a 2014 Flying Spur, and noticed that the rear seat entertainment or the lights on the picnic tables don’t work. I checked the fuses and they are good. The battery also dies every 2 days when I don’t have the maintainer on. I took it to the dealership and they said that this was the cause for the car’s battery to be drained every one or two nights. They are quoting me $6,000 to replace and continue diagnostics. Why do you think the rear TV’s or the picnic table lights don’t work? Everything else seems to be working perfect in the back. Thanks in advance!
Old 03-23-2023 | 07:51 AM
DesotoJohn's Avatar
DesotoJohn is infamous around these parts
Service Campaign EA98 - Rear Entertainment
Did the dealership reference the attached service Campaign? Unfortunately, Bentley requires a working system before this service can be performed. I attempted to attach the User manual, in case you did not have it, but system rejected the 1.2Mb file. Our RSE is not currently working and I have not pursued getting it sorted, since the grandkids haven't been in the vehicle! Good luck and keep us posted.
Old 03-23-2023 | 07:57 AM
Dgeedhar's Avatar
What year Spur do you have? Do you have the same issue? The dealership just contacted me yesterday. They are saying that the battery drain is coming from the touch screen remote in the rear. The car is constantly searching for that remote even after the car is off and locked.
Old 03-23-2023 | 08:21 AM
DesotoJohn's Avatar
We have a 2014 FS with rear entertainment. The remote functions work, except for the RSE icon, which is visible but greyed out. I replaced both batteries to address issues with prematurely draining, as both were at or near time to replace. We keep it on the charger and no issues since. I purchased the Audi equivalent batteries, but suspect a Volkswagen dealer may have them, as well. Used VAG parts to avoid dealer blaming batteries for electrical issues.
Old 03-23-2023 | 08:23 AM
Dgeedhar's Avatar
Same here. It is greyed out on the remote. The vanity mirror lights on the picnic tables do not work either. This is exactly my situation. There are new batteries which I just replaced in September and it keeps dying so I have it on the maintainer now.
Old 03-23-2023 | 09:19 AM
DesotoJohn's Avatar
If you are experiencing battery drain in a couple of days with new batteries, then that is different. We have forgotten to reconnect the charger and it did not drain the battery after 3-4 days. I keep it connected for peace of mind! Also, the vanity mirror lights on the picnic tables are working. Does your charger maintain a green light (charged)? I very seldom see the charger below full charge (green light); only for short periods after forgetting to connect it.
Old 03-23-2023 | 10:21 AM
Dgeedhar's Avatar
It takes a couple hours for the charger light to turn green. Initially it’s either on the second or third stage with orange. What is it lime for yours?
Old 03-23-2023 | 02:23 PM
DesotoJohn's Avatar
I will deliberately leave it disconnected, record which light it drops to, and then attempt to determine timeline back to green.
Old 03-24-2023 | 04:45 AM
Dgeedhar's Avatar
Do you use the CTEK magnetic gen 2 charger for Bentley?
Old 03-24-2023 | 04:57 AM
DesotoJohn's Avatar
I am using the Bentley branded charger that came with the vehicle that connects magnetically below the trunk lid.
Old 11-14-2023 | 07:16 PM
Dgeedhar's Avatar
Hi have you found a solution to your RSE not working? I finally got some time to look deeper into this issue.
cryptohodlr4life
Bentley
03-20-2023 01:17 PM
Brandoni
Bentley
10-09-2021 11:07 PM
briefremarks
Bentley
06-21-2020 02:21 AM
Gene G
Bentley
06-20-2020 06:25 PM
str8blst
12-20-2016 02:31 PM
Quick Reply: 2014 Bentley Flying Spur Rear Entertainment not working.
