Bentley flying spur lower grill removal requires acc calibration?
Old 06-15-2023 | 10:18 AM
Dgeedhar's Avatar
Dgeedhar is infamous around these parts
Hi everyone. My 2014 Flying spur has some scratches near the lower grill, and in order to get the scratches fixed, I need to remove the grill. I am not sure if the ACC would need to be re calibrated again. Thank You in advance.
Old 06-18-2023 | 05:50 AM
EJag66's Avatar
EJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud ofEJag66 has much to be proud of
While not the expert on this forum, looking at you Johnny, it shouldn't require adjustment just for the R&R of the grille. On my '14 Speed, the grille just pops out. Now I have an issue with my ACC becoming "unavailable" after a couple hours of use and made the mistake of thinking the 3 torx screws were simply for removal and not adjustment. So not only do I have the availability issue, now I get the misalignment error on the VCDS. Anyone on the forum ever built the alighnment tool?
Old 06-18-2023 | 05:54 AM
Dgeedhar's Avatar
Will the 2017 Facelift W12S grills fit the 2014 W12 flying spur?
The grills are currently broken on my 14 spur. So I was thinking of maybe replacing it with a 2017 or 18 S
model style just for the more modern look. Can somebody please recommend?
cryptohodlr4life
Bentley
03-20-2023 01:17 PM
Brandoni
Bentley
10-09-2021 11:07 PM
Gene G
Bentley
06-20-2020 06:25 PM
Curated Content Editor
Bentley
07-25-2019 06:33 PM
Indigo731
Bentley
06-12-2017 07:14 PM
Quick Reply: Bentley flying spur lower grill removal requires acc calibration?
