2012 Bentley GT Channel 43 - "17 Instrument Panel"
Old 06-17-2023 | 04:08 PM
flash32's Avatar
flash32 is infamous around these parts
Hello and good day
I believe my max mileage default was overlaid by a inferior diag tool
If someone can be kind enough and look at channel 43 in "17 Instrument panel" module and tell me what's in there
If you have a launch x431 or even a simple AP200 .. it is easily done
If someone need I can walk you thru it - probably take 5 mins tops
Thanks in advance
Old 06-18-2023 | 01:27 AM
sazam's Avatar
sazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud ofsazam has much to be proud of
you mean you want to get the values of service intervals/milages settings???
Old 06-18-2023 | 01:36 AM
flash32's Avatar
Yes
The max number of days is easy 365 but the mileage is what I am looking for
I know the workshop and user manual says 10k miles but i don't believe that was the value stored. I am not sure if the variable service feature requires a number like 100 in the valve or do I just put a fixed 16 ( km )
I am just trying to verify what the factory put in for USA cars
Old 06-18-2023 | 09:13 AM
sazam's Avatar
15000km - is the default , you can change it thru adaptation using vcds - you put multiplication of 100
when you are near to the service millage - about 3000km before you got reminder message on the dash.
you have 2012 - long coding or short coding?
i refer to my 2005 which is short coding - just to clarify.
never was interested when (and if) they mod to long coding and dont know if there were changes in defaults thru years.
Old 06-18-2023 | 09:22 AM
flash32's Avatar
Is it 15 not 16 k ?..according to the WSM I have it is 16000km which translates to 10000 miles
Hence wanting to confirm a USA version car by looking at the actual channel before i change it
I will even take a screen print of the menu from the dashboard of someone who services their car at a Bentley dealership and at what mileage it was done previously...that should give me a good idea which the need of any tools
Old 06-18-2023 | 09:23 AM
sazam's Avatar
yeah - pls wait - i am europe so km.
Old 06-20-2023 | 03:01 PM
flash32's Avatar
I updated channel 43 to 16 and channel 44 to 365
Now the info center shows a 10000 mile and one year service interval adjusted for miles/days already driven
I think this is correct ..if someone in the USA has a gen 2 w12 Bentley please attach a pic of the info center service information screen and also state mileage/date of last service .. this should confirm that my input is correct
Thank you in advance
piotreeek
Bentley
11-03-2022 06:29 AM
andyqb
Bentley
08-22-2022 12:13 PM
snguyen
Bentley
08-23-2021 07:48 AM
amokha
Bentley
04-04-2018 11:03 PM
Quick Reply: 2012 Bentley GT Channel 43 - "17 Instrument Panel"
