TPMS disable - need help using V-Checker V202
Old 08-03-2023 | 02:41 PM
mohara's Avatar
mohara is infamous around these parts
Trying to disable the TPMS warning light and need a walk-thru on how do do this using a V-Checker V202.
I removed fuse 11, connected the V-Checker, turned the ignition key to first position (engine off) select #19 for Can Bus gateway and get the following screen
If I select #2 Can Bus Mode I get a comms error and cannot proceed any further. If I select # 1 NOT Can Bus Mode I get the following screen
Here I get stuck. If I hit the up or down arrow it goes to the following page:
If I select #2 it shows the TPMS error code. If I select #4 it says fault code erased, but when I turn off and turn back on again the TPMS warning light stays on.
I know a few of you have successfully erased the warning light using the V-Checker so I'm hoping you can walk me through it step by step.
In case you cant see my signature line, the car is a 2007 GT
Thanks for any and all suggestions !
jsmith141182
Bentley
45
07-04-2022 07:42 AM
tess1234
Bentley
07-02-2020 05:11 PM
telum01
12-29-2017 09:43 PM
slafporsche
911
06-04-2015 08:00 AM
Quick Reply: TPMS disable - need help using V-Checker V202
