Replacing AGM Battery?
No success on a search of the archives.
Appreciate any tips on removing the large AGM battery (located on left side on US versions.
Removing the negative connector is easy, but the configuration of the positive setup has me stumped.
Any other hold downs as well?
Thanks.
Thanks.
I first looked at doing it that way, however removing the connections from the positive battery block is much easier that removing and replacing that trunk wall panel so that's what I did.
