Bentley GT driver's seat entry/exit "convenience" button
Old 03-03-2024 | 04:33 PM
tteplitzmd's Avatar
tteplitzmd is infamous around these parts
This round black button on the left side of the steering wheel column, should turn on/off this "convenience" feature.
I read the manual but I can't figure out how to make the setting for the seat to move back upon exiting/entering the driver's seat.
I can't make sense of the manual. Currently pressing the button does nothing.
If anyone can tell me what I need to do I would appreciate it.
Old 03-04-2024 | 04:42 AM
1st Bentley's Avatar
1st Bentley is infamous around these parts
I inquired about this exact same feature on mine. All that small button does, is allows the steering wheel raise up when exiting the car. To get the seat to move all the way back on it's own when exiting the car simply doesn't exist.
Old 03-04-2024 | 05:16 AM
tteplitzmd's Avatar
Pushing the button with the ignition on or off does nothing on mine. Is there something else I have to do?
Old 03-04-2024 | 05:49 AM
hq_'s Avatar
hq_
hq_ is infamous around these parts
Leave the button on and wonderful things start happening whenever you shut down the engine and open the driver's door. It's just a master switch for the convenience feature which activates in certain situations as described, the button itself doesn't trigger any immediate action.
Old 03-04-2024 | 05:56 AM
tteplitzmd's Avatar
Thanks, but how do you tell if it's on or off? I guess I have to try turning off the ignition and opening the door, and if nothing happens, push it again and repeat.
Old 03-04-2024 | 06:26 AM
hq_'s Avatar
hq_
IIRC, button stays in = it's on. You may want to confirm this, I've only tried the feature once and even though I didn't care to continue using it, it seemed to work.
Old 03-04-2024 | 06:27 AM
tteplitzmd's Avatar
Mine doesn't stay in. Probably not worth worrying about it.
Thanks for your prompt replies.
belton
Bentley
07-09-2023 05:14 PM
belton
Bentley
11-14-2022 11:14 AM
spav
Bentley
10-24-2021 04:30 AM
GTSeth
Bentley
09-24-2021 02:53 AM
wilschroter
Bentley
10
01-16-2012 07:03 PM
Quick Reply: Bentley GT driver's seat entry/exit "convenience" button
