Bentley gtc 2013 won't start
Hi guys I'm new to this got a gtc v8 tt the car had no batteries in wen it got delivered fitted new batteries still no start checked the dtc no major ones to point you in the direction. Then noticed there was no communication with some off the modules
Abs module
Esp
Tcm
Battery management
Possibly more can't remember
Sent abs pump and module off for testing came back as fine checked all wiring to abs there fine
Also can't do a battery adaptation
Any ideas guys
Abs module
Esp
Tcm
Battery management
Any ideas guys
Hello @V8 Choppa ,
Please give a little history of the vehicle, in what condition is it, any body damage, or water damage, as it has 14 faults for the KESSY alone, do you have more than one keyfob, does the instrument cluster power up at all, is there any immobilizer message on the driver's information screen, have you checked every fuse, even the mega fuses, have you tried the key in the ignition vs. push button start ?
Johnny
Johnny
Hello @V8 Choppa ,
Johnny
Johnny
Car is running
Hi it turned out there was a after market tracker with immobilizer removed that and it started it's now in low voltage mode on the dash board any recommendations
AlanGTC
11-25-2020 04:18 AM
Francesca20
06-14-2019 07:02 AM
