Exhaust Gas Temperature Sensor EGT Bank 1 - Short to Ground
Old 05-10-2024 | 05:49 AM
mrc00l88's Avatar
mrc00l88 is infamous around these parts
16929 - Sensor 1 for Exhaust Temp Bank 1 (G235)
P0545 - 002 - Short to Ground
Are there any fuses, or the like to check for this code?
Or is replacing the circuit board/sensor itself the fix?
To confirm, bank 1 is on the left side (passenger USA) while standing infront of the vehicle looking at the engine?
Thank you
Old 05-11-2024 | 05:19 PM
BentleyF's Avatar
BentleyF is infamous around these parts
its a cold solder joint. just open and remove gel inside and resolder 5 connection on the board. Ive doe this on 5 Bentleys ive owned and the fault has never returned.
Old 05-27-2024 | 09:04 AM
Mars911's Avatar
Mars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond reputeMars911 has a reputation beyond repute
Bentley F,
How did you get the case/box open? I have tried on mine, but have not been able to get it off. Also, do you have pictures showing how you got it apart? Did you just pry it open?
Also, I found the following and I have ordered the two boards on the attached and am planning on giving it a shot.
https://www.audiworld.com/forums/2-7...-good-2850845/
exilebrit
01-24-2024 07:50 AM
OK51MON
07-20-2016 03:57 PM
qvt408
01-21-2011 06:40 AM
DNugget991GT3
08-19-2008 10:21 AM
sharkster
05-16-2004 07:34 PM
Quick Reply: Exhaust Gas Temperature Sensor EGT Bank 1 - Short to Ground
