V8 Turbo Oil Screen replacement
Old 06-26-2024, 06:25 AM
daf290's Avatar
daf290 is infamous around these parts
After doing much research, I believe that I will be replacing the dreaded turbo oil screen on my 2014 V8.
Have any of you done this and do I need to remove the entire front bumper cover to get at the fasteners for the oil separator or can I pull the front cover down a bit and reach
them?
lots of Audi videos about doing this but nothing for our Bentley’s.
Old 06-27-2024, 06:45 PM
Chessey's Avatar
Chessey is infamous around these parts
The issue you’ll have is removing the oil separate. It will hit the radiator fans when you slide it forward before the piping comes free. You would have to loosen and slide the front end module(radiator pack) forward a bit to make space.
Old 07-01-2024, 06:58 AM
daf290's Avatar
So I must pull the fenders (wings) and bumper cover and put the radiator into the service position as the only way to remove the oil separator?
no easier way?
Old 07-01-2024, 07:17 PM
Chessey's Avatar
Maybe if you can get the radiator fans out some how it may give the the room you need
daf290
Bentley
05-30-2024 04:06 AM
Ashton Martian
10-01-2023 04:58 PM
plenum
08-16-2015 06:26 PM
topspeedua
05-10-2012 06:26 PM
bond
01-31-2006 11:07 AM
Quick Reply: V8 Turbo Oil Screen replacement
