Bentley Continental GT - Company Comfort Databus in Single Wire Fault
Hi all,
I am working through problems with my vehicle and trying to interpret the logs from the scan to see if there is a common factor or starting point linking the problems and am hoping that some of you extremely knowledgeable people will be able to help.
The background is a repeated flat left hand battery which was partially due to lack of use and was then made much worse with cold weather. Initially the starter battery always worked when using the key but then both batteries died and I was unable to access the boot / trunk to charge. When I eventually managed to get into the car and start charging several faults were found on the scans and whilst investigating I found that the wheel well was full of water from a blocked drain in the lid.
The main issue now is that the boot / trunk will not operate properly and will not lock, even when closed manually, and just pops back open. The other most noticeable faults are the rear view camera and NAIM sound system not working.
This brings me to the reason for this post. Whilst reading multiple threads of other users issues and looking at the advice given I am lead to think the problems are related but are more likely a result of the battery issues and not necessarily due to the water ingress.
Looking back the first problem I noticed, many months ago, was the drivers door handle not locking with the touch sensor. The scan shows this as a short to ground and, after all the reading on other issues, this has got me wondering if this is the root cause of the problems. Could this be causing the battery drain and ultimately the canbus / databus single wire faults?
I have replaced the left hand battery this weekend and the scan below is with the new battery.
I have also tried to re-code the 07 control head and it says the code has been accepted but still does not show it on the screen.
Could someone please point me in the right direction to try and get to the bottom of these issues.
Many thanks
Keith
PS I have also posted this on the Ross-Tech forum but had no replies yet.
Many thanks
Keith
Code:
Code:Monday,08,July,2024,08:36:24:23029 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64 VCDS Version: 24.5.0.0 (x64) HEX-V2 CB: 0.4643.4 Data version: 20240429 DS355.0 www.Ross-Tech.com VIN: SCBCF63W5AC063905 License Plate: G21MFC Mileage: Repair Order: 08072024 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 3W (6N0) Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 19 34 36 37 38 46 47 53 54 57 65 68 6C 71 76 77 VIN: SCBCF63W5AC063905 Mileage: 143210km-88986miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 11-Engine II -- Status: OK 0000 31-Engine other -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 34-Level Control -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Cannot be reached 1100 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 54-Rear Spoiler -- Status: OK 0000 57-TV Tuner -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 68-Wiper Electr. -- Status: Malfunction 0010 6C-Back-up Cam. -- Status: Cannot be reached 1100 71-Battery Charger -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine ( ) Labels: 07C-906-018-BWR1.clb Part No SW: 07C 906 018 GK HW: 07C 906 018 HE Component: BY - 6.0 L - TT G 5027 Revision: --H03--- Serial number: VWX3Z0I3872932 Coding: 0001075 Shop #: WSC 00083 790 00000 VCID: 74B1D22082AEB0FA43B-5160 VINID: 8D34935860E71514C0183240144FE805CC No fault code found. Readiness: 1110 0001 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 09E 927 760 AH HW: GS1 911 4 Component: ZVAC3605 6L W12TT 3605 Revision: --H04--- Serial number: 0133637 Coding: 0000111 Shop #: WSC 00083 790 00000 VCID: 76B5E82894D2A2EA7DF-5160 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 3W0-614-511.clb Part No SW: 3W0 614 511 H HW: 3W0 614 511 H Component: ESP 8.1 4WD H01 0650 Revision: 00000000 Serial number: 00000000000000 Coding: 0002308 Shop #: WSC 00083 790 00000 VCID: 34311220C22EF0FA83B-5160 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl Part No SW: 3D0 909 137 F HW: 3D0 909 137 F Component: 74 Kessy 6850 Revision: 00H22072 Serial number: VWX3Z0I3872932 Coding: 0422125 Shop #: WSC 00083 790 00000 VCID: 2A0D0C5810BAB60A297-807E Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX 1 Fault Found: 00190 - Driver's Door Handle Touch Sensor (G415) 007 - Short to Ground Freeze Frame: Fault Status: 01100111 Fault Priority: 3 Fault Frequency: 0 Reset counter: 100 Time Indication: 0 Date: 2024.07.05 Time: 17:52:50 ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: 3W0-959-759.clb Part No: 3W0 959 759 E Component: CM Seat Pass. 0023 Coding: 0000002 Shop #: WSC 35443 002 1048576 VCID: 4BC369DCBF808F02F21-801E 1 Fault Found: 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent ------------------------------------------------------------------------------- Address 07: Control Head Labels: 3D0-035-00x-07.lbl Part No: 3W0 035 007 P Component: ZAB COCKPIT 2270 Coding: 0000000 Shop #: WSC 35443 002 104857 VCID: 392F2314E54C0D9250D-5160 2 Faults Found: 01044 - Control Module Incorrectly Coded 000 - - 00463 - Control Module for Digital Sound Package (J525) 004 - No Signal/Communication ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 3W7-907-040.clb Part No: 3W0 907 040 F Component: Climatronic BY614 2014 Coding: 0000111 Shop #: WSC 00000 000 00000 VCID: 34311220C27EF0FA83B-8060 2 Faults Found: 00716 - Air recirculation Flap Positioning Motor (V113) 014 - Defective 00229 - Refrigerant Pressure 002 - Lower Limit Exceeded ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels:. 3D0-937-049-V2.clb Part No SW: 3D0 937 049 M HW: 3D0 937 049 M Component: J519 6500 Revision: -4004--- Serial number: -------------- Coding: 40020000AB2A11000000000000000000 Shop #: WSC 00083 790 00000 VCID: 34311220C27EF0FA83B-8060 No fault code found. ------------------------------------------------------------------------------- Address 11: Engine II Labels: 07C-906-018-BWR2.clb Part No SW: 07C 906 018 GK HW: 07C 906 018 HE Component: BY - 6.0 L - TT G 5027 Revision: --H03--- Serial number: VWX3Z0I3872932 Coding: 0001075 Shop #: WSC 00083 790 00000 VCID: 74B1D22082AEB0FA43B-5160 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: None Part No SW: 3W8 909 601 HW: 3W8 909 601 Component: 15 Airbag 9.41 H14 0040 Revision: 91H14004 Serial number: 0039L000FAGV Coding: 0012597 Shop #: WSC 00083 790 00000 VCID: 7BA3F91CAFF0FF82021-5160 Subsystem 1 - Serial number: 63328RB404E2A5FF0 Subsystem 2 - Serial number: 63428RB404E2B3E8Z Subsystem 3 - Serial number: 63528RB404E2ACB5 Subsystem 4 - Serial number: 63628RB404E2B3FD0 Subsystem 5 - Serial number: 63700RB4 I Subsystem 6 - Serial number: 63800RB4 J No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 7L6-953-549.lbl Part No: 7L6 953 549 L Component: J527 3601 Coding: 0000232 Shop #: WSC 00083 790 00000 VCID: 48C956D0AEF6641ADF3-801C No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 3Wx-920-xxx-17.clb Part No SW: 3W0 920 841 J HW: 3W0 920 841 J Component: J285 KOMBI-INST. 2226 Revision: K0H10V40 Coding: 0007402 Shop #: WSC 80093 222 69422 VCID: 3C213A00EA6E38BA4BB-8068 1 Fault Found: 00470 - Company Comfort Databus in Single Wire 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 172 Mileage: 143216 km Time Indication: 0 Date: 2024.07.06 Time: 09:02:24 ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 6N0-909-901-7L.clb Part No SW: 6N0 909 901 HW: 3W0 920 841 J Component: J533 GW-K-CAN TP20 2226 Coding: DFF8FF2E9F0E4701 Shop #: WSC 80093 222 69422 VCID: 70B9DE30F6A68CDAA73-8024 3 Faults Found: 00463 - Control Module for Digital Sound Package (J525) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 172 Mileage: 143215 km Time Indication: 0 Date: 2024.07.05 Time: 17:06:44 02873 - Control Module for Back-Up Camera (J772) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 172 Mileage: 143215 km Time Indication: 0 Date: 2024.07.05 Time: 17:06:44 00470 - Company Comfort Databus in Single Wire 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 172 Mileage: 143216 km Time Indication: 0 Date: 2024.07.06 Time: 09:02:24 ------------------------------------------------------------------------------- Address 34: Level Control Labels: 3Wx-907-553-34.clb Part No: 3W0 907 553 E Component: LUFTFDR.-CDC- 3C3V0 7213 Coding: 0005571 Shop #: WSC 00083 790 00000 VCID: 3C213A00EA2E38BA4BB-8068 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: 3W0-959-759.clb Part No: 3W0 959 760 E Component: CM Seat Driver 0023 Coding: 0000002 Shop #: WSC 35443 002 1048576 VCID: 43D341FC97D047420A1-8016 1 Fault Found: 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent ------------------------------------------------------------------------------- Address 37: Navigation Labels: None VCID: 55F78FA46D44C9F2545-8000 No Faults Found or DTCs not supported by controller or a communication error occurred ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: None Part No: 3W0 907 135 F Component: Dachmodul 0802 Coding: 0006589 Shop #: WSC 00083 790 00000 VCID: 392F2314E51C0D9250D-806C No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 3D0-959-933.clb Part No: 3D0 959 933 H Component: 1X HSG 0200 Coding: 0000040 Shop #: WSC 00083 790 00000 VCID: 35372F24C954E9F2B45-4B1E Subsystem 1 - Part No: 3W8 959 701 J Component: Tuersteuergeraet FS 1106 Subsystem 2 - Part No: 3W8 959 702 J Component: Tuersteuergeraet BF 1106 Subsystem 3 - Part No: 3W8 959 703 D Component: Tuersteuergeraet HL 0703 Subsystem 4 - Part No: 3W8 959 704 D Component: Tuersteuergeraet HR 0703 Subsystem 5 - Part No: 3W0 909 610 F Component: 14 HDSG 1809 5 Faults Found: 00470 - Company Comfort Databus in Single Wire 012 - Electrical Fault in Circuit 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent 01134 - Alarm Horn (H12) 004 - No Signal/Communication 00485 - Drivers Outside Door Handle Central Locking Button (E369) 007 - Short to Ground 00896 - Trunk Lock Unit (F256) 008 - Implausible Signal ------------------------------------------------------------------------------- Address 47: Sound System Cannot be reached ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 3W0-907-801.clb Part No SW: 3W0 907 801 E HW: 3W0 907 801 E Component: EPB BC7H0270 HC7 0270 Coding: 0022413 Shop #: WSC 00083 790 00000 VCID: 38292610DE46149AAF3-5160 No fault code found. ------------------------------------------------------------------------------- Address 54: Rear Spoiler Cannot be reached ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: None Part No SW: 3D0 919 148 HW: 3D0 919 148 Component: TV-Tuner 0160 Revision: R0H16000 Serial number: 91100500611102 Coding: 0000003 Shop #: WSC 35443 002 1048576 VCID: 678BB56CC3284B62F69-8032 1 Fault Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 1 Reset counter: 40 Time Indication: 0 ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 3D0-907-273-V4.clb Part No SW: 3W7 907 273 A HW: 3W7 907 273 A Component: J0502 RDK 0004 Revision: 0004 004 Serial number: 00000900007000 Coding: 3501E052A5F9A5A5F9A7DA00A7DA00 Shop #: WSC 00083 790 00000 VCID: 3E253008FC322AAA65F-806A No fault code found. ------------------------------------------------------------------------------- Address 68: Wiper Electr. Labels: 3Wx-955-023.clb Part No: 3W2 955 023 G Component: Wischermodul 9328 Shop #: WSC 00000 725 65552 VCID: 3B23391CEF203F82421-806E 1 Fault Found: 01336 - Company Data Bus for Comfort System 004 - No Signal/Communication ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Cannot be reached ------------------------------------------------------------------------------- Address 71: Battery Charger Labels: 3D0-915-181.lbl Part No: 3D0 915 181 D Component: Batteriemanagement 2800 Shop #: WSC 00000 000 00000 VCID: 2411E260729E607A13B-8070 1 Fault Found: 00003 - Control Module 014 - Defective ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 3W0-919-283-V2.clb Part No SW: 3W0 919 283 D HW: 3W0 919 283 D Component: J446 ST Parkhilfe 0094 Revision: 11H04001 Serial number: 90030920801866 Coding: 0101006 Shop #: WSC 00083 790 00000 VCID: 3E253008FC322AAA65F-806A No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: None Part No SW: 3W0 035 385 AT HW: 3W0 035 385 AT Component: rSAP Bentley 0264 Revision: 00008000 Serial number: 30900000107681 Coding: 0031000 Shop #: WSC 00083 790 00000 VCID: 074B95ECE368AB62169-8052 No fault code found. End----------(Elapsed Time: 03:25, VBatt start/end: 12.3V/12.2V)----------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 07,3W0 035 007 P,recoded (Short coding),from,0000000,to,0453227,(35443/002/104857), -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 06: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 07,3W0 035 007 P,recoded (Short coding),from,0000000,to,0400337,(35443/002/104857), -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Sequential Output Tests
sam08861
Bentley
61
03-03-2023 12:30 AM
