Garage opener not resetting or flashing
So I got my build sheet from Bentley and it’s got Garage Opener on it but when I use the remote reset push of buttons 1-3 I get no reset flashing.
i have the key turned to on but engine off as described in the manual for reset.
any ideas?
Build sheets states this:
Coming Home' Controls ( Garage / Electronic Gate Opener ) (GRT VC1) Cost Option
thanks chap.
paul
ps - used the doc on this thread for reset instructions
Reset Garage Door pdf
any ideas?
thanks chap.
paul
All I can say is that the HomeLink opener on my earlier '09 GT died and my current '16 GT one has never worked since I bought it 2 years ago. I gave up trying and just use a remote clipped to my visor.
I'm thiking its goosed tbh, but I'm about to add my Amazon Alexa so I will probably just link that up.
Paul,
I had the same issue with my 2017 GTC i.e. unable to see the flashing light to erase previous setup.
I recommend holding buttons 1 and 3 for at least a 30 seconds and move on to the next step. The light has a very low intensity which may not be visible in an open outdoor space. You might also try programming the buttons in the garage with the garage door closed. It worked for me and I’m able to program the button to my garage.
Good Luck
Brian
Good Luck
Brian
Paul,
Good Luck
Brian
Good Luck
Brian
Hello @CUE99T ,
I know that you stated no flashing, but it there any illumination at all ?
Have you checked the #5 fuse in the facia fuse box ?
#5 is for the roof module, and may have to do with the garage opener.
Johnny
Johnny
PS can you point me to a door trim strip so I can check my keyless entry as poer the other thread please mate? - Sorry for cross-thread chat....
7and911
08-20-2014 03:43 AM
advantyper
01-29-2013 05:13 PM
