'05 BCGT Alarm issues
My alarm system seems to be malfunctioning. When the car is locked, either by the fob or physical key, the 4 way flashers run continuously and there is a faint alarm sound. This happens with or without the battery tender plugged in. Anyone know what is going on here? Is there a reset proceedure that may rectify this, or is something more serious going on? Any advice will be appreciated.
I was able to get it connected to a OBD computer and it reported that the alarm siren was dying. I was able to acquire one from Flying Spares. The siren is located behind the left rear tire well sheathing. It is attached with tamper proof nuts. This is really a dumb application of tamper proof nuts as the tire needs to be removed and then the well liner, at which time in the event of theft the alarm would have been sounding for 10 minutes. The removal socket for the tamper proof nuts is currently not available at $240. Rediculous price for a socket. I ground small flats on the side of the nuts and tapped them off with an awl and hammer. Replaced them with nyloc nuts. Problem solved and the alarm is back in service with the other symptoms gone. This car is actually a 2006 BCGT.
I'm glad you got it sorted your self.
XWCGT
09-07-2023 12:15 PM
DNugget991GT3
07-22-2009 11:38 AM
