Bentley GT door issue
Hi all, I have just got a 2005 Bentley GT and I am absolutely loving it so far, however there are a few gremlin issues that I am working my way through…
the issue I am trying to figure out currently relates to the drivers door.
sometimes (from outside) the door will open with one single pull of the door handle (minor window drop and door open - as expected), other times I have to pull the door handle twice- once drops the window and then I pull it again and the door itself opens.
another issue is that sometimes from inside, pulling the door handle doesn’t open the door. I have to pull it 5 or 10 times before it eventually engages the release mechanism and opens the door.
I’m assuming this is an adjustment issue but before I dive into it head first I thought I’d ask here in case any one has experienced a similar issue.
any advice or guidance is gratefully received!
