e60 M5 Increased Emmisions
Old 04-01-2009 | 10:30 AM
ezmoney888's Avatar
ezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond repute
Anyone get this fault yet? I need to bring it to the dealer but I have an evosport exhaust. As far as I know, the O2 sensors are ahead of the exhaust so any increase in emissions would be coming from before the exhaust and not a result of the exhaust, correct?
Old 04-01-2009 | 09:49 PM
TCM's Avatar
TCM
TCM is infamous around these parts
Very common fault on the E60 M5. Happens a lot up here in the northeast with colder temps. The exhaust definitely did not cause the warning and I am fairly certain you will not have a hard time getting it done under warranty. Check out www.m5board.com for more detailed info. Great forum.
Old 04-02-2009 | 08:35 AM
omarm's Avatar
omarm is infamous around these parts
increased emissions is usually an error that comes up with any CEL. you need to get the error codes read to find out what the actual fault is...
Old 04-02-2009 | 10:01 AM
stevenshin's Avatar
stevenshin is infamous around these parts
I posted my response to a similar question M5board as well..... I had an "Increased Emissions" light and it turned out to be a "failed evap system" code. They replaced or replugged a vacuum hose in the passenger side rear under warranty.
Old 04-04-2009 | 10:55 AM
ezmoney888's Avatar
I had O2 sensors replaced.
1gr8e39
10-01-2015 04:07 PM
porschecayenne92
09-20-2015 08:43 PM
porschecayenne92
Cayenne
09-12-2015 01:26 PM
Quick Reply: e60 M5 Increased Emmisions
