How to make the fastest 335i.
Well, for me, the goal is just outright speed.
I would also be looking ahead as to who is doing tuning with upgraded turbos.
I would also not discount the CP-E standback system which seems to allow far more tuning options if you want to get insanely serious about it.
You don't want to swap turbos... I would be willing to.
Well they will all do better with bolt on's, definitely, especially when tackling the exhaust system.
No problem, we are here to talk cars
I see you dont want to swap turbos but I would contact ASR and let them take care of you because they know what their doing and you could drive there.
ASR does not have their own tune, more about hardware, they go with Vishnu/PROcede.
If you don't want to spend large sums of money, go with a JB3 2.0 or Vishnu/Procede V4, with a dual cone intake, downpipes, exhaust and meth injection. That set up can do high 11.7-11.9 at 125-128 mph.
I personally have the JB3 2.0 with the DCI (no DP's, exhaust or meth) and on Map 7 with a mix of race gas it will do 12.3 at 118 mph+-.
My set up cost less than $700. DPs, exhaust and meth will probably run another $1.5-2K.
if you consider as the most fastest, and not the most HP, u should think of trimming some weight!!!,
e.g: akrapovic exhasut, superlight wheels, etc, trim weight off, and add HP will make it way way better!!! as to fastest, and handle well,
I did that to my m3 too, a very noticeable handling difference, i fitted Akra only, and the first thing i feel is lighter, it actually feels sharper, on the next day i had some 19inch 20ib wheels fitted, and it make hell lot of difference on braking accel, etc, just way better,
dun just think of adding hp, trim some weight
