335i sport line , Wheels/Tires feet question , need your help
got 225/45/18 for all the 4 tires.
i'd like to install wider rear tires.
and to buy 19" wheels.
there is: Size for example 19X9 Offset (ET) Center Bore
how i know what size i need to buy for wheels?
also for tires ? i think i will buy the pilot super sport
there is so many manufacture for wheels
can you name few names/models that are good quality and finish?
and if they are light then the stock it's great !
i really like the wheels that coming with M3 competition package , i think they called ZCP
those wheels can feet or they are to wide , etc. ?
do you have some options to recommend ?
what tires size will feet in my car? without touch the fenders
ront Wheels - 19x9" ET31 (25.4 LBS, 31mm offset) - BMW Part # 36-11-2-284-055
Rear Wheels - 19x10" ET25 (26.6 LBS, 25mm offset) - BMW Pat # 36-11-2-284-060
this is the size of OEM M3 CZP wheels , those can feet?
You have an F30 correct?
On the F30 most of my guys are running much more conservative specs than the M3 CZP wheels and they're pretty flush with the fenders. Typically I suggest going with something closer to an 8.5 wide ET35 wheel up front and a 9.5 wide ET35 out back for guys wanting something aggressive. If you want something a little "safer" (aka less chance of rubbing) at 9.5 wide ET45 gives you enough room for tire size selection without rubbing but still looks great.
19s look fantastic on the F30; the Alzor 730s, Miro 111 or GT7s, or even the soon to be fully released 3SDM .06s would complement the lines rather well. All of these are avaible in sizes which would be proper for the F30. HERE is link to these wheels in 19 inch fitment.
If you wanted to stick with 18s and wheel that would accommodate a wider than 225 tire. There are still a host of great wheels I'd look into Alzor 716s have a classic BMW design to them (LINK). VMR V718 capture the CSL/Competition look in a proper for your F30 size (LINK). 3SDM broke the mold with the controversial in the BMW community pentastar 0.05s (LINK)
On the F30 most of my guys are running much more conservative specs than the M3 CZP wheels and they're pretty flush with the fenders. Typically I suggest going with something closer to an 8.5 wide ET35 wheel up front and a 9.5 wide ET35 out back. This gives you enough room for tire size selection without rubbing but still looks great.
19"
what is my options?
what tire size i should get?
For the CSL style wheel the VMR V710 (LINK) is very popular, I'd suggest going with the 19x8.5 ET35 up front and 19x9.5 ET45 out back combo and running a 245/40/19 in the front and 275/35/19 in the rear. This is personality the wheel and tire combo I'd run on an F30 335i.
If you wanted to go with something a little more rounded the Miro 111 would also work for you and comes in a 19 inch fitment for the F30. But at the current time I'd only suggest a squared set up for these, the rear fitment is a bit too aggressive for the F30. HERE is a link to the 111s in matte black in 19x8.5 ET35 fitment. On these you could run squared 245/40/19, or do a staggered 235/40/19 255/35/19 combo.
The MRR GT7s (LINK) fall in to the aggressive fitment category for the F30 with their 19x8.5 ET35 and 19.5 ET35 rear set up. On these I'd run the 245/40/19 in the front still but out back I'd stretch a 255/35/19. This isn't optimum for daily driving but fits the wheels to the car.
I'll include some larger photos to make the details of the wheels easier to see.
wow , 275 !
do you have a pic to see how it look like
very wide tires
04-28-2022 12:38 AM
