Hartge's V10 3-Series Coupe
Back again this year: the HARTGE H50 V10 under the guise of the E92 3 Series Coupe. The first thing that strikes you is the two-tone paintwork, then the ventilated bonnet and front wings, as well as the HARTGE front spoiler lip and HARTGE boot spoiler.
From the Saarland region, the H50 V10 features a thermo-dynamically optimised bonnet. In addition, HARTGE's engineers and mechanics have achieved an extraordinary feat of engineering: the installation of a modified M5 V10 engine producing 550 hp (404 kW) and a torque of 520 Nm, which is coupled to a 7-speed SMG transmission and de-restriction to 320 km/h.
To help the H50 V10 put all this power onto the road, it is also fitted with a reinforced rear axle and a special suspension system that can be adjusted not only for height but also for rebound and compression.
Also especially made for the HARTGE H50 V10 is the stainless steel exhaust system, which makes the V10 sound an acoustic delight. Customers can choose between dual twin oval or dual twin round tail pipes.
The wheel/tyre combination consists of 9 x 20" offset 40 wheels at the front and 10 x 20" offset 40 at the rear fitted with Pirelli 245/30 ZR 20 and 295/25 ZR 20 tyres respectively.
Last but not least: inside the HARTGE H50 V10 besides a 330 km/h speedometer, the first things you notice are the carbon interior trim, the 3-spoke steering wheel with carbon inserts and the leather/aluminium brake handle.
With the H50 V10, HARTGE maintains its long tradition of building wolves in sheep's clothing for individualists who prefer understatement.
HARTGE H50 V10 Coupé (based on 325i / E92)
Engine:
Cylinders: 10
Displacement: 4999 cc
Bore / Stroke: 92.0 x 72.2 mm
Performance: 404 kW / 550 hp at 7750 rpm
Max. torque: 530 Nm / lb-ft 391 at 6100 rpm
Fuel grade: Unleaded, 98 Octane
Euro norm: Euro 4
Gear box: 7-speed SMG
Gear ratios:
1 = 3.99 : 1
2 = 2.65 : 1
3 = 1.81 : 1
4 = 1.39 : 1
5 = 1.16 : 1
6 = 1.00 : 1
7 = 0.83 : 1
Rear axle ratio: 3.45 : 1
LSD: 0 – 100 %
HARTGE equipment:
E60 M5 V10 engine with reworked cylinder heads, sports camshafts, bespoke engine mapping, 7-speed SMG gear box, special exhaust system with new manifolds, reinforced and adjustable wheel suspension.
HARTGE stainless steel rear silencer with dual twin oval or dual twin round tail pipes, left and right HARTGE adjustable sports suspension, 30 mm lower Brakes:
- 380 mm 2-piece perforated floating disks front with 8-piston fixed brake callipers
- 345 mm 2-piece perforated floating disks rear with 4-piston fixed brake callipers
HARTGE bonnet, ventilated
HARTGE rear wing
HARTGE set of carbon housings for exterior mirrors
HARTGE CLASSIC 2 wheel set
- 9 x 20" offset 40 with 245/30 ZR 20 Pirelli Nero
- 10 x 20" offset 40 with 295/25 ZR 20 Pirelli Nero
HARTGE carbon interior trim for dashboard, gear lever panelling and door handles
HARTGE speedometer 330 km/h
HARTGE leather/aluminium handbrake handle
HARTGE aluminium pedals (2)
Set of HARTGE velours floor mats, black (other colours upon request)
HARTGE set of emblems for bonnet and boot lid
Performance:
Acceleration 0-100 km/h / 0-62 mph:
4.4 s
Maximum speed:
320 km/h / 200 mph
Weight DIN:
1670 kg / 3676 lbs.
Weight distribution, front / rear:
52.0 / 48.0
RRP:
157,650.00 EUR including 16% VAT
Technical data and prices are subject to changes without notice. November 2006
Article from http://www.worldcarfans.com/rsslink....-h50-v10-coupe
What a sweet machine! I posted this in a "Modified 335's" thread about two weeks ago but it never gets old seeing a V10 stuffed in a sleek coupe body
EDIT: but i didnt know the info on the car....WOW, $157,xxx!!!!! Thanks for sharing that....guess ill cross it off my Christmas list!
Originally Posted by 4Thirty
...a special suspension system that can be adjusted not only for height but also for rebound and compression.
Oh wait, that's an average coilover.
Seriously, it's an amazing car, I just love how manufacturers blow things out to make them sound extraordinary and astounding.
"Our vehicle has an innovative new system that disperses particles in wave form to help increase your visual accuity during periods of less than desirable visibility." Translation - headlights help you see better at night.
Here is a video of it and its 4-door variant in action http://www.youtube.com/watch?v=kRLfkQY2Wos
C5tt
10-24-2015 07:35 PM
ECS Tuning - BMW
09-29-2015 01:18 PM
