M5 Launching...
Old 02-01-2007, 12:34 PM
PeterC4C's Avatar
PeterC4C has much to be proud ofPeterC4C has much to be proud ofPeterC4C has much to be proud ofPeterC4C has much to be proud ofPeterC4C has much to be proud ofPeterC4C has much to be proud ofPeterC4C has much to be proud ofPeterC4C has much to be proud ofPeterC4C has much to be proud ofPeterC4C has much to be proud of
all else fails RTFM
Old 02-01-2007, 03:06 PM
buddyg's Avatar
Wow that is pretty sad, most cars you just mash the gas and go. On this thing you have to program it to be in the right mode?? No offense but kind of sounds dumb to me.
Old 02-01-2007, 08:05 PM
vtgts300kw's Avatar
vtgts300kw is infamous around these parts
Originally Posted by SlowMotion
I did not hold the shift lever... I'm assuming the (+) lever would be the right lever!
Where is this rubber button and what does it do generally? Are you saying it's behind the pedal? Does it doe anything other than cause the car to "Launch".
I can't wait to try this!
Seth.
its mounted on the firewall directly behind the accelerator. with the car off, push the accelerator as far as it will go, you should feel it pushing/resting against a raised button like object, push the accelerator down harder so as to push the button down as well. its called a kick down button and in automatic bmw's, if you punch it and activate this button, the car drops down a gear straight away. [i think thats its purpose]
but in the m5, you have to push this button down to activate the launch control.
play aroud with it [ somewhere empty and deserted]
and make sure your m settings are as the others have stated.
Old 02-01-2007, 08:46 PM
20C4S's Avatar
no kidding. i'm with u on that. BMW sure likes to make things complicated.
