GMP Performance Presents Macht Schnell for the 1-Series, 3-Series, 1M and M3
Rating: Thread Rating: 2 votes, 5.00 average.
Old 09-03-2013 | 01:09 PM
GMP Performance's Avatar
Site Sponsor
Macht Schnell is a BMW-specific tuning company dedicated to developing & manufacturing the finest products available. Dedicated to providing the finest in quality high performance and aesthetic modifications to assist in maximizing the most from your BMW through experience and innovation, they are able to individualize your BMW to suit your specific needs. We do not offer any performance accessory that they believe does not significantly enhance the performance of your vehicle.
Whether it be on the street or the track – their relentless pursuit of advancement and dedication can be clearly seen through their product line as BMW owners should expect nothing less. And now, GMP Performance to offer that entire product line for all of our customers to truly get the best of their BMWs!
Macht Schnell For The 1-Series, 3-Series, 1M and M3
Perfomance
BMW E9X M3 Macht Schnell Stage 2 Intake Charge Kit
Macht Schnell is proud to announce the all new Stage 2 Intake Charge Kit for the e9x M3.
Designed under the idea of function over form, Macht Schnell is the first to develop a proven intake system that compliments the already efficient M3 air box. By replacing the restrictive stock filter with a larger, more free-flowing performance filter the engine is able to breathe air easier.
Also replaced is the stock, accordion style intake elbow that connects the air box to the intake manifold. The Macht Schnell replacement Intake Charge Pipe (ICP) has very smooth and glossy interior walls and is 18% larger by volume, eliminating the turbulence and resistance that the stock elbow produces. The elbow is constructed from super strong polyethylene and has a textured exterior that perfectly matches the texture of the OEM intake manifold for a stock look. Included are Macht Schnell's own Intake Charge Scoops, making a matched combo that provides maximum air delivery for your S65 engine with noticeable power gains.
Heavy duty rubber intake couplers and European worm style clamps are included to maintain a tight seal while allowing engine movement. A 6061-T6 anodized aluminum inlet is embedded into the Macht Schnell Intake Charge Pipe to retain the stock PCV system.
Package Includes:
- Macht Schnell cotton gauze high performance air filter
- Macht Schnell intake charge scoops
- Macht Schnell intake charge pipe & filter adapter
- Heavy duty rubber intake couplers
- European style worm clamps
Macht Schnell Stage 2 Intake Charge Kit Features:
- Aids in additional airflow to factory airbox, providing additional gains of 8-12hp
- Deeper and more aggressive intake sound
- Washable/reusable cotton gauze high performance air filter allows for more airflow
- Polyethylene construction, nearly indestructible
- Elegant textured exterior, smooth polished gloss interior for maximum air delivery with no restriction
- Will not rust, or deteriorate over time
- Sturdy sidewall construction ensures filter will last the life of the vehicle
- Tight leak proof seal with your factory air box
- Deepest multi-layered pleats increase air flow and maintain critical protection levels, while still providing maximum air delivery
- Maintains OEM filter’s 99% debris collection efficiency to meet ISO 5011 standards
- Maintains BMW engineered pressurized air box and OEM appearance
BMW E9X M3 Macht Schnell Stage 1 Intake Charge Kit
Macht Schnell is proud to offer a high quality, high performance and high protection original equipment direct replacement air filter – specifically for your S65 powerplant. Combined with our Intake Charge Scoops (ICS), this matched combo will provide maximum air delivery for your S65 engine with noticeable power gains.
The ICS pieces are constructed from nearly indestructible polyethylene, which prevents heatsoak and will not bend, distort or rust after years of use. The inside of the ICS pieces have a smooth radius with a gloss finish to direct airflow into the intake snorkel while the outer edged are black textured to emulate factory pieces, giving a stealth appearance.
Intake Charge Scoops (ICS) Features:
- Aids in additional airflow to factory airbox, additional gains when combined with Macht Schnell High Performance Filter
- Elegant textured exterior, smooth gloss inner for maximum air delivery with no restriction
- Sold as a set
Each Macht Schnell filter is designed to the specific requirements of your engine it will be protecting to deliver top-level performance with maximum flow and filtering. Pleat depth, quantity and filtering media configuration are tuned to provide the best possible performance without compromising the protection required for today’s high tolerance engines.
Maintaining proper CFM flow and particle capture efficiency is a delicate balancing act. Filters that flow well usually do not protect as well and vice versa. Macht Schnell has mastered the formula to achieve this elusive perfect balance and so your engine assets will perform better without sacrificing protection.
S65B40 High Performance Panel Filter Features:
- Direct replacement for your original equipment filter panel
- Washable/reusable cotton gauze which allows more airflow
BMW E9X 335 Macht Schnell Stage 1 Intake Charge Kit
Macht Schnell is proud to offer a high quality, high performance and high protection original equipment direct replacement air filter – specifically for your N54 powerplant. Combined with our Intake Charge Scoops (ICS), this matched combo will provide maximum air delivery for your N54 engine with noticeable power gains.
- Sold as a set
Our N54B30 High Performance Panel Filter is the ultimate first step for someone that wants to maintain and improve upon the highly engineered stock intake systems. This is an engineered filter constructed specifically for your BMW to deliver maximum airflow.
N54B30 High Performance Panel Filter Features:
BMW E82/88 135i & 1M Macht Schnell Stage 1 Intake Charge Kit
- Sold as a set
BMW E82 1-Series & 1M/ E9X 3-Series & M3/ E85 Z4M Macht Schnell Aluminum Lightweight Battery Enclosure for Braille Batteries
Stock BMW batteries can weigh in at approximately 60-65lbs. A lightweight battery is a great way to shed unwanted pounds for vehicles that see extended track use. However a smaller battery footprint means it will not fit in the same location without fabricating your own mounting solution.
Macht Schnell Battery Enclosures are CNC-machined from the same aerospace 6061-T6 lightweight billet aluminum as our Competition Wheel Spacer kits and feature a black anodized finish which is strong and non-corrosive to withstand grueling conditions while keeping your battery worry-free. Simply put - these are the finest-engineered battery enclosures available for your BMW. Your stock BMW battery can be easily swapped at any time during off-season.
Features:
- Machined from 6061-T6 aerospace aluminum
- Overall footprint are exact dimensions of stock BMW battery, engineered for a perfect fit
- Shaves approximately 50lbs from stock battery setup
- Holds battery securely in place
- Top-mounted terminal indicator can be reversed for left/right positive terminals
- Black anodized finish for additional strength and corrosion/wear resistance
- Macht Schnell logo engraved in holder
- Easily swapped for stock battery at any time
- Weighs only 2.5lbs
- Includes corrosion-resistant hardware
BMW E9X 3-Series & M3 Macht Schnell Intake Charge Scoops
Factory BMW intake systems are well known to be very efficient – particularly on the M models. The Macht Schnell Intake Charge Scoops (ICS) assist in air delivery by diverting cold, fresh air from behind the kidney grilles into the airbox, with a noticeable power gain found at higher speeds on vehicles equipped with our High Performance Filters. The ICS pieces are constructed from nearly indestructible polyethylene, which prevents heatsoak and will not bend, distort or rust after years of use.
Features:
- Sold as a set
BMW E82 1-Series & 1M Macht Schnell Intake Charge Scoops
Factory BMW intake systems are well known to be very efficient. The Macht Schnell Intake Charge Scoops (ICS) assist in air delivery by diverting cold, fresh air from behind the kidney grilles into the airbox, with a noticeable power gain found at higher speeds on vehicles equipped with our High Performance Filters. The ICS pieces are constructed from nearly indestructible polyethylene, which prevents heatsoak and will not bend, distort or rust after years of use.
Features:
- Sold as a set
BMW E9X M3 Macht Schnell S65B40 High Performance Air Filter
Our S65B40 High Performance Panel Filter is the ultimate first step for someone that wants to maintain and improve upon the highly engineered stock intake systems. This is an engineered filter constructed specifically for your BMW to deliver maximum airflow.
Features of the S65B40 High Performance Panel Filter:
- Eliminates the charcoal-impregnated lining found in OEM filters better airflow
- Maintains OEM filter\'s 99% debris collection efficiency to meet ISO 5011 standards
BMW E82/88 135i/ E82 1M/ E9X 335i/ E60 535i/ Z4 sDrive 35i N54 Macht Schnell N54B30 High Performance Air Filter
Macht Schnell is proud to offer a high quality, high performance and high protection original equipment direct replacement air filter - specifically for your N54 powerplant. Each filter is designed to the specific requirements of your engine it will be protecting to deliver top-level performance with maximum flow and filtering. Pleat depth, quantity and filtering media configuration are tuned to provide the best possible performance without compromising the protection required for today’s high tolerance engines.
Features of the N54B30 High Performance Panel Filter:
BMW M3/ M5/ M6 Macht Schnell Performance Underdrive Pulleys
Free additional power to your M3/M5/M6’s rear wheels without sacrificing or compromising your BMW’s reliability.
Machined from 6061-T6 aerospace aluminum, Macht Schnell Performance Underdrive Pulleys are strong as well as lightweight to limit parasitic drag from the accessories within a moderate level for maximum performance on or off the track. After machining and engraving, pulleys are then T3 hard anodized for additional strength, anti-corrosion & wear resistance.
Our DualDrive design replaces the Crank Accessory & Power Steering Pulleys, resulting in a 18-20 HP and 16-20ft. lbs TQ gain for the M5/M6 and a 9-14 HP and 7-9ft. lbs TQ gain for the M3. Gains are due to a reduction in power required to turn accessories; an increase in accessories lifespan due to lower speed will also result. All factory harmonics/balancing are undisturbed.
Macht Schnell Performance Underdrive Pulleys have no negative effect on accessory operation and come fully equipped with new belts.
Performance Underdrive Pulleys Features:
- DualDrive design allows maximum performance, with minor affect on accessory speed
- Proper cooling temperatures are retained at proper levels on or off the track
- Maintains proper alternator speed, allowing sustained levels to sensitive control modules
- T3 Hard-Anodized for maximum strength and corrosion/wear resistance
- No affects to crankshaft dampening or harmonics
- Simple bolt-on installation
Exhaust
BMW E9X M3 Macht Schnell Bypass Track Pipes
On the S65 V8 M3 models, the stock exhaust headers flow very well while the catalysts present the largest obstacle and power loss. the Macht Schnell Bypass Track Pipes were designed specifically for race/track use, and offer a cost-effective means of removing the 400 cell restrictive primary catalytic converters on all 2008-2013 M3s. Bypass Track Pipes allow you to make two single cuts to your stock midpipe section, removing the catalytic converters, and clamping the largest diameter straight pipe in their place using the provided high-end/premium exhaust clamps. This eliminates the largest source of exhaust restriction, unleashing considerable power gains (~20hp) and a very obvious improvement in acceleration.
Macht Schnell Bypass Track Pipes permit you to retain your OEM secondary cats and resonators, keeping noise levels tame enough for even the most stringent sound limitations found at many track events (nearly stock decibel levels), and also keeping costs to a minimum. No welding is required for installation, simply cut and bolt into place using supplied exhaust clamps.
Aftermarket software required to prevent Check Engine lamp from illuminating.
Bypass Track Pipe Features:
- Full Stainless Steel Construction, with mandrel bends for optimum flow
- Straight shot design for zero restriction and high velocity
- Gains as high as 20hp/20lb-ft TQ with no aftermarket software
- Retains OEM O2 locations
- Retains use of OEM crush gaskets
BMW E8X 135i/1M/ E9X 335i N54 Macht Schnell 76.2mm (3.00”) Catless Track Downpipes
With a maximum output of 306 hp from 2,979 cc the 135/335’s N54 powerplant ensures exceptional driving dynamics at all times with all the power of a much larger normal-aspiration engine. Twin turbochargers each forcing compressed air into three cylinders ensure a standard of spontaneity never seen before in a turbocharged power unit. The big advantage of these relatively small turbochargers is their low inertia, avoiding excessive “turbo gap” – the moment which usually passes by until the turbocharger builds up its boost – typical of a conventional turbocharged engine. On the road, therefore, the turbocharged power unit of N54 variant offers all the power and performance of a much larger normally-aspirated engine.
Stock downpipes cause a major restriction in exhaust flow coupled with their small 57mm (2.25″) pipe diameter and numerous crush-bends with factory pre-cats squeezed in engine compartment. This results in excessive backpressure and excessive heat, which ultimately affects overall performance at all RPM loads.
Macht Schnell’s 76.2mm (3.00″) N54 Catless Track Downpipes allow instantaneous turbo spooling and ultra-low backpressure proving significant hp/tq gains that can be felt immediately after installation.
Mandrel-bent T304 Stainless Steel tubing is used to ensure constant exhaust flow is achieved by eliminating any restrictions, resulting in maximum gains and noticeable sound during turbo spooling. TIG-welded construction and Stainless Steel V-Band/catback flanges are durable as well as pleasing to the eyes. Heavy Duty exhaust gaskets and Stainless locking fasteners complete the package.
Stainless O2 sensor bung locations are mounted in the factory locations while introducing additional stainless steel thermocouple bungs for those monitoring EGTs.
Downpipe Features:
- 76.2mm overall diameter, eliminating restrictive factory pre-cats and crush bends
- 100% T304 Stainless Steel construction, using mandrel bends
- Precision TIG welded joints
- Heavy-Duty Stainless V-Band/Exhaust flanges
- Heavy-Duty locking fasteners and exhaust gaskets included
- Factory O2 locations retained with Stainless Steel bungs
- Pre-installed Stainless EGT bungs for easy thermocouple mounting
- Reduced underhood temperatures
Interior
BMW E9X 3-Series & M3 Macht Schnell Ashtray Gauge Panel
Monitor your engine’s vitals and race with confidence while adding some style points with our ashtray gauge panel for your 3-series BMW.
The Macht Schnell gauge panel is an exact component replacement for your stock BMWs ashtray, comfortable housing three 52mm gauges within and angled for easy viewing. The textured finish allows an OEM feel as if this were offered from your local BMW parts counter. Injection molded from ABS plastic, this panel will resist warping or bending in high-heat applications. The smooth textured finish is a perfect match for your BMWs interior, giving the OEM-like appearance you expect.
The Macht Schnell ashtray gauge panel mounts using the factory ashtray mounting holes with no drilling or gluing necessary.
Gauges not included.
Features:
- Gauge panel houses three 52mm gauges
- Injection molded ABS plastic construction
- Textured finish to match interior design
- Mounts utilizing factory ashtray mounting locations, no drilling necessary
BMW E82 1-Series & 1M Macht Schnell Ashtray Gauge Panel
Monitor your engine’s vitals and race with confidence while adding some style points with our ashtray gauge panel for your 1-series BMW.
Features:
BMW Manuals Macht Schnell MS97 Spec Shifter ****
Instantly give your BMW the race car look and feel by installing Macht Schnell's MS97 Spec Shifter ****.
The increased height of the MS79 **** means that the shifter is positioned closer to the steering wheel. This allows the driver to make quicker shifts and focus more on steering input. Machined from nylon 6/6 material, the MS97 Spec Shifter **** is precision made to easily install (pressure fit, no screws) on your BMW's OEM shifter rod. Because it is made of nylon rather than aluminum or leather, this shifter **** also helps to reduce the transferred heat from the transmission. The elegant black design looks both functional and aggressive.
Features:
- 97mm height
- Black nylon 6/6 construction
- Machined for precision fit and feel
- Moves the shifting position closer to steering wheel
Electronics
BMW 1-Series/ 3-Series/ M3 Macht Schnell OC3 Seat Occupancy Sensor Emulation Module
For those running race seats, the Passenger Occupancy Sensor Mat (OC3) is now an integral part of the OEM seat leather and cannot be ordered separately - triggering a “Passenger Restraint Error” message that hijacks the iDrive/OBC, rendering it useless.
Macht Schnell has come up with a solution for those running fixed-back shells and want to retain their iDrive/OBC displays with an OC3 emulator module that easily ties into your BMWs wiring with no cutting or splicing needed and can be removed at any time. For those running race harnesses, the Macht Schnell OC3 module will properly emulate seatbelts in the fixed position - eliminating any errors caused to allow you to focus on on the track and win.
The Macht Schnell OC3 Seat Occupancy Sensor Emulation Module is possible of the following features:
- The ability to run racing seats with no system errors, allowing full integration
- Elimination of “Passenger Restraint Error” messages on both iDrive and OBC cluster displays while in use
- Proper emulation of passenger OC3 Seat Occupancy Sensor
- Optional emulation of seatbelt receptacles (fastened position for both driver & passenger) for those running race harnesses
- Allows the use of BMW Performance Seats, which are not compatible with US models
- Completely removable at any time
BMW E82 1-Series & 1M/ E9X 3-Series &M3 Macht Schnell TPMS/RDC Emulation Module
Tire Pressure Monitoring System (TPMS) is an electronic system designed to monitor the air pressure inside all the pneumatic tires on all BMWs manufactured since 2006. Within a predetermined pressure level, a RF signal (433mHz) is sent to each of the receivers located in the wheelwells. These systems report an error message to the driver when pressure is low.
Battery-powered Radio Frequency based TPMS have several disadvantages. Batteries eventually become exhausted and represent a maintenance cost to the consumer. Batteries are chemical systems with lifetimes that unfortunately perform very poorly in extreme temperature environments typical of North America and European climates and in aerospace applications. In order to conserve battery life and to conform to various countries communication authority standards for short range radio communications, the power levels of battery powered TPMS are kept very low . As a consequence of these very low power levels, the construction of certain steel belted radial replacement tires and vehicle metallic geometries can block the low power signal transmission paths.
The so-called total cost of ownership for direct systems is much higher than for indirect systems due to battery and wheel changes and broken/damaged parts. Replacement TPMS sensors from your local dealer can be in excess of $300USD/set with the lithium batteries mounted in the sensors with a 5-6 year shelf life. Aftermarket sensors are not generally reliable.
For those that have multiple tire sets for the track, this is simply not practical. Our TPMS/RDC Emulation Module installs in less than 15 minutes and will fully emulate a full-pressure TPMS signal when activated. Module can be activated/deactivated by lifting up on the driver’s side window switch for +5 seconds with the key off.
- The ability to run racing tires/wheels or other environments in which TPMS sensors are not compatible
- Easy 15-minute installation process with no wire cutting
- Proper emulation of the TPMS/RDC monitoring system
- No dealer visits or coding required after installation
BMW E9X M3/ E60 M5/ E63 M6 Macht Schnell Electronic Dampening Control (EDC) Emulation Module
For those wanting to move away from EDC for aftermarket suspension systems or coilover setups, the EDC monitoring can be a bit obtrusive as this type of monitoring is no longer required - resulting in numerous error messages thinking the system has malfunctioned. Our EDC Emulation Module installs in less than 15 minutes and will fully emulate a fully active EDC environment when activated. Module can be activated/deactivated by via the integrated mini USB port within the module housing.
Electronic Damper Control (EDC) from BMW reduces variations in wheel load, ensures tires have excellent traction and counteracts bodyshell movement regardless of the weight your automobile may be carrying - and regardless of the state of the road’s surface. EDC can even help shorten braking distances, meaning you enjoy outstanding comfort along with the best in BMW on-road safety. Sensitive sensors constantly monitor all factors influencing the vehicle’s behavior and occupants’ comfort, including road conditions, load changes and vehicle speed. In a fraction of a second, the signals are analyzed by the EDC microprocessor and orders are sent to the actuators on the shock absorbers, which, with the help of magnetic valves, are variably adjusted to provide optimal suspension.
The Macht Schnell EDC Emulation Module is possible of the following features:
- The ability to run aftermarket racing suspension/coilover setups in which EDC monitoring is not required
- Compatible with iDrive and non-iDrive systems
- Proper emulation of the EDC monitoring system
Wheel Spacers
BMW Macht Schnell Competition Wheel Spacer Kit
Available in:
03mm /// 05mm /// 10mm /// 12mm /// 15mm /// 18mm /// 20mm
In order to give your BMW a much more aggressive stance while increasing handling, we offer our line of Macht Schnell Competition Spacer Kits.
Machined from 6061-T6 aerospace aluminum, these adapters are strong as well as lightweight to limit unsprung/reciprocating weight for maximum performance on or off the track. Spacer edges are also chamfered to allow for easy installation/removal if needed. After machining, the spacers are then anodized for additional strength, anti-corrosion & wear resistance.
A wider track stance increases lateral stability as well as giving your BMW a much more aggressive appearance after installation. Spacers also are used to correct wheel gap normally seen on otherwise stock suspension setups, pushing the wheels outward - filling the fenders.
Included with our Competition Wheel Spacer Kits are a full set of extended lug bolts. All wheel fasteners are hardened and tempered to strength class 10.9 or 10 according to DIN/ISO standard 898 and meet the statutory requirements of all countries - including the US.
Competition Wheel Spacer kit Features:
- Chamfered edges allows installation & removal quick and easy
- Improve handling by reducing body roll with a wider wheel base
- Included zinc plated corrosion-resistant wheel fasteners
Competition Wheel Spacer kit Contents:
- (2) Competition Wheel Spacers
- (10) Extended-length zinc plated coated wheel fasteners
Tracking
BMW E82 1-Series/1M & E9X 3-Series/M3 Macht Schnell H2O Gauge Boss
Macht Schnell H20 Guage Bosses are made of high strength aircraft aluminum 6061 alloy material, cut and machined using the most advanced manufacturing technology, and is designed to withstand high temperatures without compromising durability and reliability. After machining, bosses are then anodized for additional strength, anti-corrosion & wear resistance.
Perfect fit for the different hoses and water-tight to prevent leaking. Heavy duty hose clamps included.
BMW E82 135i/1M & E9X 335i/M3 Macht Schnell Oil Distribution Block
The Macht Schnell Oil Distribution Block allows a quick and painless way to integrate a 1/8" NPT, generally used for auxiliary oil pressure/temperature gauges or even a supercharger feed line. Machined from T6 billet aluminum with black anodized finish.
The Oil Distribution Block is designed to mount in the stock oil pressure sending unit location, allowing the use of an aftermarket sending unit or supercharger feed line. An additional port is present to retain the factory Oil pressure sending unit, maintaining the use of the factory oil pressure light. As aftermarket sending units can be quite large depending from manufacturer to manufacturer, the steel braided line allows remote installation.
Steel braided line and and crush washers are included. Designed for use with most aftermarket 1/8" NPT sending units (Stack, AEM, SPA, VDO).
Kit includes:
- Macht Schnell Oil Distribution Block
- 18" Steel Braided Line for aftermarket sending unit relocation
- 1/8" NPT Aluminum 90-degree Adapter
- Aluminum Crush Washers
BMW E9X M3 Macht Schnell DCT Gauge Boss
The Macht Schnell DCT Gauge Boss is made of high strength aircraft aluminum 6061 alloy material, cut and machined using the most advanced manufacturing technology, and is designed to withstand high temperatures without compromising durability and reliability. After machining, bosses are then anodized for additional strength, anti-corrosion & wear resistance.
For DCT-equipped M3s at higher power levels, or see regular aggressive/track use - the DCT may enter "limp mode" when fluid temperatures see critical levels. The DCT gauge boss allows for monitoring of DCT temperature, permitting counteractive measures to be taken in order to prevent this from happening.
O-rings and replacement spring washer are included. Dual 1/8" NPT ports allow for temperature monitoring either before or after the heat exchanger. Designed for use with most aftermarket 1/8" NPT sending units (Stack, AEM, SPA, VDO).
Allows for the temperature gauges to read both before and after the heat exchanger.
BMW E82/8 1-Series & 1M/ E9X 3-Series & M3 Macht Schnell Motorsport Tow Straps
The Macht Schnell Motorsport Tow Strap eliminates the need for the factory tow hook or aluminum versions which can cause damage in a collision. Plus they add a touch of motorsport flair to your BMW.
Features:
- 1.75" Harness width
- 6000lb Harness Tensile Strength, heavy duty cross-stitching
- CNC stainless steel tow eyelet
- 2 TOW arrow decals included, in standard and reverse orientation
- Safer alternative to fixed factory tow hook or aftermarket aluminum versions
- Can easily be tucked away behind tow hook cover or slit protrusion
- Direct replacement for factory tow hook
- Sold individually, 2 required per vehicle
- Easy installation & removal
Brackets and Harness Receptacles
BMW E82 1-Series & 1M / E90/2 3-Series & M3 Macht Schnell Competition Lightweight Floor Mounts for Racing Seats
Race seats can offer a an immediate improvement in driver feedback keeping you planted to the seat and concentrated on driving, while offering a significant weight savings. However, most race seat companies leave it up to the driver for a mounting solution.
Macht Schnell Floor Mounts are designed for the serous track enthusiast in mind. CAD designed and machined from 6061-T6 aerospace aluminum, these mounts are as strong as they are light. Multiple mounting positions allow driver to dial in an exact seat position that is most comfortable and perfectly centered to the steering wheel.
Competition Liteweight Floor Mount Features:
- CAD designed and CNC machined from 6061-T6 aerospace aluminum
- Allows fitment for Recaro and most other race seats on the market
- Fully compatible with slider brackets
- Low profile allows for sliders or taller drivers allowing helmet clearance
- Side provisions allows brackets (sold separately) for OEM seatbelt receptacle mounting or race harnesses
- Available in Black Anodized or Raw Aluminum finish
- Can be used on Driver or Passenger's side
- Sold as a set (one seat)
BMW 1-Series/ 1M/ 3-Series/ M3/ Z4/ Z4M Macht Schnell Steel Seat Shell Adapter/Side Mount for Recaro Seats
Macht Schnell’s steel seat shell adapter/side mounts are required for mounting your RECARO seat to your floormounts or sliders.
Features:
- Allows RECARO seats to mount securely to floormounts
- Steel construction for highest level of strength and durability
- Gloss black powdercoat finish
- Multiple mounting holes offer fixed decline/recline adjustment
- Fits Pole Position, Profi, Profi XL, Pro Racer HANS SPG XL & Pro Racer SPA AL
BMW 1-Series/ 1M/ 3-Series/ M3/ Z4/ Z4M Macht Schnell Hybrid Seatbelt/Harness Receptacles for Competition Liteweight Floor Mounts
Allows a safe mounting point for OEM seat belt receptacles and/or bolt-in harnesses. Can run stock 3-point seatbelts, 4/6-point harnesses, or even both at same time. Perfect for those vehicles that see both Street & Track duty.
For use with Macht Schnell Competition Liteweight Floor Mounts. Not compatible with clip-on harness mounts.
Note: 4/6-point harnesses require optional submarine bracket.
Crafted from high-grade steel with a durable black powedercoat finish.
BMW 1-Series/ 1M/ 3-Series/ M3/ Z4/ Z4M Macht Schnell Clip-In Harness Receptacles for Competition Liteweight Floor Mounts
Allows a safe mounting point for clip-in harnesses. For use with Macht Schnell Competition Liteweight Floor Mounts.
BMW 1-Series/ 1M/ 3-Series/ M3/ Z4/ Z4M Macht Schnell Bolt-In Harness Receptacles for Competition Liteweight Floor Mounts
Allows a safe mounting point for bolt-in harnesses. For use with Macht Schnell Competition Liteweight Floor Mounts.
BMW 1-Series/ 1M/ 3-Series/ M3/ Z4/ Z4M Macht Schnell Aluminum Seat Shell Adapter/Side Mount for Recaro Seats
Macht Schnell’s aluminum seat shell adapter/side mounts are required for mounting your RECARO seat to your floormounts or sliders.
Features:
- Aluminum construction for strength and weight savings
- Black or clear anodized finish
BMW 1-Series/ 1M/ 3-Series/ M3/ Z4/ Z4M Macht Schnell 6-Point Harness Steel Submarine Bracket
Allows a secure anchor location for your 6-point harness submarine belts. For use with Macht Schnell Liteweight Floor Mounts.
Made from extremely strong and durable steel.
Features:
- Compatible with 5-point and 6-point harnesses
- Includes hardware
- Bolt-in installation
The phrase “Macht Schnell” means “hurry up”, “Go ahead!” or “Make it quick!”. Macht Schnell likes to take this phrase and make it their foundation: “speed through power”. For everything they craft, that foundation can be found throughout the process, all to come to you and your BMW.
For more information, click any of the links for each or feel free to message us with any questions!
Chris Green@USP
997 Turbo Vendor Classifieds
01-28-2016 03:22 PM
jyupitt1
09-23-2015 07:26 AM
orbelo
08-30-2015 01:26 PM
Chris Green@USP
996 Turbo Vendor Classifieds
08-20-2015 12:30 PM
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
