Twin Turbo Boxster
Old 10-24-2007, 11:54 AM
Gary in BR's Avatar
Gary in BR is infamous around these parts
Twin Turbo Boxster
I have finally taken a few pictures of my twin turbo setup.
Granted this is no 500hp monster. But the power is delivered early in the rpms, smooth and last all the way to redline.
Its a low boost setup, only 6psi.
The intercooler is mounted beneath the car, I have had this set up for over 4 months and have had no issues with it at all.
AS far as power goes, peak power is on 60hp, but across the rpm it varies, at some points its almost 75 over stock.(5100rpm)
The tourqe comes on low at 3000 rpms my baseline toruqe was around 135 whereas the turbo was 170.
I have a little more tweaking to do before the setup is at 100%.
At http://www.youtube.com/watch?v=jOunWKqkh80 you can see the video of my dyno.
Old 10-24-2007, 05:17 PM
JRL's Avatar
JRL
JRL is offline
JRL is infamous around these parts
I think your link is was bad. Nice car!
Old 10-24-2007, 05:22 PM
jex's Avatar
jex
jex is offline
jex Is a GOD !jex Is a GOD !jex Is a GOD !jex Is a GOD !jex Is a GOD !jex Is a GOD !jex Is a GOD !jex Is a GOD !jex Is a GOD !jex Is a GOD !jex Is a GOD !
Outstanding! What is the difference in your 0-60 and 0-100?
Old 10-24-2007, 05:32 PM
01986's Avatar
01986 is infamous around these parts
what is the max boost? did you do any internal work? will this be easier than do a 3.4 swap? which is faster??? thanks!
Old 10-24-2007, 07:00 PM
pwrbrkr38's Avatar
pwrbrkr38 is infamous around these parts
nice shots... thanks for sharing
Old 10-24-2007, 07:04 PM
BoxsterGirlie01's Avatar
BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !BoxsterGirlie01 Is a GOD !
beautiful! just by seeing your boxster, it makes me want to add some items to my "wish list" now!
nice job!
Old 10-24-2007, 07:14 PM
Dino V's Avatar
nice! Looking forward to seeing your project complete.
Old 10-24-2007, 07:23 PM
weedo's Avatar
weedo has much to be proud ofweedo has much to be proud ofweedo has much to be proud ofweedo has much to be proud ofweedo has much to be proud ofweedo has much to be proud ofweedo has much to be proud ofweedo has much to be proud ofweedo has much to be proud of
Thumbs up
Very cool! What sort of before/after numbers are you putting down on the dyno? I know you're not done with the tuning yet, but I'm sure everyone is curious!
Keep us posted on your progress. Love the project...
Old 10-24-2007, 09:07 PM
easyc's Avatar
easyc is infamous around these parts
Gary, Im at the track all weekend, but when I get back Ill get to that avatar...
Old 10-25-2007, 12:19 AM
blinkwatt's Avatar
blinkwatt is infamous around these parts
Gary your ride is coming along NICE.
I noticed something that could be a BIG issue. You know that aluminum plate you removed to install the intercooler? I heard the car can't hold an alignment w/o it in place and secured,did Turbowex say that it was o.k. to remove?
Old 10-25-2007, 09:19 AM
Gary in BR's Avatar
Old 10-25-2007, 09:23 AM
Gary in BR's Avatar
I was unaware of that.
I will find out today, thanks.
Old 10-25-2007, 09:33 AM
deputydog95's Avatar
deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !
Seems like a very complex/expensive setup for 60-75hp. Is it possible to safely turn up the boost? What was the cost to do this? It seems well executed though. Why the custom turbo over the supercharger kits that are available?
Old 10-25-2007, 09:37 AM
Also, I'm assuming the IC is an air to air? Does it get enough flow and is there something underneath that channels the air through it.
Old 10-25-2007, 09:38 AM
JP-S-St.Louis's Avatar
Just a boxster?
JP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond repute
Ddog not without doing some internal mods.. Simple fact is that the 60-70 HP increase is all relative to the stock power the engine makes. Just as your 120 or so HP increase is to the 3.4. It is all in the percentage of increase vs stock.
Quick Reply: Twin Turbo Boxster
