AP short shifter is awesome
First off, the Agency Power shifter uses a very smooth bearing design for thorough engagements without the notchy feeling. The CNC machined housing and shift lever provide maximum efficient to go between the tough gears such as 1-2 and 3-4. I see your in PHX... Come by a shifter and I will give you 50% off the labor rate. If you dont like it, I will put it out for free.
here are some lame pics...:)
remove the shifter cap
remove the screws
slide up the handle
tap up the handle mount carefully
remove the handle base and boot
remove screw and outlet from subwoofer
remove screws with long Torx driver
remove the screws
slide up the handle
Mystery screw like this or with a long thin Torx driver
remove consoul screws
remove electrical clip for center consoul, slide consoul back and out
shifter linkage, you may want to mark these before removing the shifter
cut off the clips from the stock bushing
drop in the new
drop in the new
from what Agency Power told me, yes. Please email me dan@vividracing.com so I can take care of you.
Dan
Dan
It is about 2 hours. Here is the installation instructions - http://www.agency-power.com/blog/tec...-installation/
