19's carrera s wheels on cayman s
Old 08-10-2009, 10:43 PM
solrac6262's Avatar
solrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to all
Hello guys,
quick question for the experts, I am planing on upgrade to a set of carrera s wheels, using spacers, is it ok to do this any suggestions? does it affect the car at all not using the correct size?
thanks all..
Old 08-13-2009, 02:38 PM
CAT/J's Avatar
CAT/J is infamous around these parts
Ive got some that I may be willing to sell
Switched over to HRE's after about 3k miles. Wheels are clean, No curb rash...but Im in California...shipping may not be friendly, but theyre light for 19's!
mr.castellanos@yahoo.com
Old 09-08-2009, 08:29 PM
Cayman Cab S's Avatar
Cayman Cab S is infamous around these parts
Originally Posted by solrac6262
Hello guys,
thanks all..
I'm no expert, but my 05 Boxster S came with Carrera S 19" wheels. They are listed as an option. No spacers needed.
Old 09-08-2009, 11:36 PM
notquitefob's Avatar
notquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud of
the 19 inch wheel options on the cayman are specifically made in the cayman offset. simply taking a carrera wheel and putting it on a cayman will not fit.
Old 04-17-2012, 04:08 PM
split's Avatar
split is infamous around these partssplit is infamous around these partssplit is infamous around these partssplit is infamous around these parts
^ any idea what the difference is? perhaps the rears just need a small spacer?
Old 04-19-2012, 04:43 PM
alex911s's Avatar
alex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond repute
if it's from a Carrera you would need spacers in the rear at least 23mm..
Carrera rear offset is 65... stock offset on Cayman wheels are 42's i believe..
the fronts should fit ok..
Old 04-19-2012, 09:41 PM
Fluid987's Avatar
Fluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond repute
. Looks good
Old 04-20-2012, 05:20 PM
syaero's Avatar
syaero is infamous around these parts
I, too, have an 05 Boxster S that came with the Carrera S 19" but I'm not sure if it's the same exact wheel use on the Carrera S. I suggest checking with the local Porsche Dealer to confirm the size and fitment. I do believe the wheels are different for each model.
2lflat4
11-18-2019 05:05 PM
Sterlingc1975
08-22-2015 02:30 PM
PelicanParts.com
964
08-18-2015 03:57 PM
PelicanParts.com
08-18-2015 03:49 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
08-18-2015 03:42 PM
Quick Reply: 19's carrera s wheels on cayman s
