2006 Cayman S Service?
Hi 6speeders,
I am in the market for a used Cayman and i found one and I read the carfax and listed it below. It says at 32,120 miles the engine was removed for repair and engine cleaned. Is this normal service at that mileage? Any help would be great. Please see below.
05/31/2007 8,115 McKenna Motors
www.mckennacars.com Antifreeze/coolant flushed/changed
Maintenance inspection completed
Oil and filter changed chassis lubricated 05/08/2008 19,865 McKenna Motors
www.mckennacars.com Maintenance inspection completed
Manufacturer's recommended maintenance performed 09/04/2008 25,201 McKenna Motors
www.mckennacars.com Battery charged
Battery replaced
Two tires mounted and balanced 12/15/2008 31,368 McKenna Motors
www.mckennacars.com Tire repaired
Tires replaced
Windshield replaced 02/10/2009 32,102 McKenna Motors
www.mckennacars.com Engine removed for repair
Alignment checked
Headlight bulb replaced
Engine cleaned
thank you
Battery replaced
Tires replaced
Alignment checked
Engine cleaned
thank you
cnebrask
10-03-2024 08:19 PM
2lflat4
11-18-2019 05:05 PM
GrantRR
06-28-2018 03:33 PM
