987 S offsets...
Which wheel and size (width)? E.g., standard 18x9 that comes on the 987s (Boxster S), the rear offset is 43. 19x10 should be around 36 - at least that's what they are for my Champion wheels.
If you have the wheel, the 9X7 wheels should have the offset and width stamped on either side of the valve stem.
Once you get the car, look at the offset of the wheels (should be stamped as mentioned), then find a off-set calculator to determine the size/offset. If you buy wheels made for the Boxsters/Cayman, you'll be fine. If you want to go with a more aggressive offset, then get some spacers to "shim" the wheels out a bit. If you stay with factory 19" wheels (there are a number of them), wheels will sit flush with fender by using 5mm front/15mm in back. If you go aftermarket wheels... Get the wheels first, then determine how aggressive you want to go
Spacers should have zero affect on alignment settings, provided they're hub-centric.
that was my mistake... i didn't get the car re-aligned for them. had bad wear on the inner.
DBB
01-07-2016 09:32 AM
jdbaker
09-19-2015 10:34 AM
