noise downshifting to 4th gear
Old 06-23-2010 | 07:33 PM
jim-x's Avatar
jim-x is infamous around these parts
no ,I bought it at 35k and now it as about 40k
Old 06-26-2010 | 07:11 AM
jim-x's Avatar
trying to check and change the tranny oil , but a need a special tool for the plug . I'Il get it done on monday.
Somebody said I could be low on transmission oil . It does't show when I drive and shift in low speed but in higher speed the oil moves more and doesn't cover the gears.
any opinions ?
Old 06-28-2010 | 02:53 PM
Erik@GBox's Avatar
Erik@GBox is a jewel in the roughErik@GBox is a jewel in the roughErik@GBox is a jewel in the roughErik@GBox is a jewel in the rough
If you are getting grinding and the oil change does not help it, I would say that you are probably in need of a rebuild. New synchronizers will in all probability be the order of the day. Not sure what you would be looking at in terms of cost from an INDY there in Montreal, but these gearboxes will typically run about $3000 or so to rebuild. Could be less, but it is a pretty safe figure unless you for some reason have ring and pinion damage, which it pretty unlikely.
Hope that this helps,
Erik Johnson
GBox Performance Transaxle
(303) 440-8899 work
(303) 895-4828 cell
www.gboxweb.com
Old 06-29-2010 | 08:44 AM
ToddPhilly's Avatar
ToddPhilly is infamous around these parts
Sure sounds like a bad syncro to me. Rebuild likely necessary.
Old 06-29-2010 | 03:02 PM
jim-x's Avatar
Thanks for the info guys .
I just got the tranny oil changed today .(it was low)
I'll test it for a few days .
My mecanic said about the same as you guys.(bad syncro)
Old 06-30-2010 | 11:13 AM
GTgears's Avatar
GTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond repute
Any update on how it drives now?
Old 07-04-2010 | 05:21 AM
jim-x's Avatar
no more noise . But I'll really put it to the test in my next Track day in 2 weeks . So like you guys suggested , the first thing to check is the level of the tranny oil and the 2th is to change that oil..
thanks again and I'll keep you post it in 2 weeks
Bmanny
09-16-2015 08:29 AM
Yogi911
09-09-2015 08:20 PM
GSP
09-09-2015 05:31 AM
andbos
09-07-2015 07:13 PM
Saint Ari
09-04-2015 03:30 PM
Quick Reply: noise downshifting to 4th gear
