Cayman and 11x19
Old 10-18-2010, 04:56 PM
Giorgos Cayman's Avatar
Giorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond repute
Cayman and 11x19
A friend gave me his wheels from a 996tt,The front are the same with CS 8,5x19 same offset with same tires 235-35-19.The rear wheels is the problem,
11x19 and the tires are 315-25-19 (offset 45),I know that is not right but what kind of spacers I need?
Old 10-18-2010, 05:23 PM
Tay Tay's Avatar
Tay Tay has a spectacular aura aboutTay Tay has a spectacular aura aboutTay Tay has a spectacular aura about
are you lowered?
Old 10-18-2010, 07:08 PM
sleek-sam's Avatar
sleek-sam is infamous around these parts
Arent the offsets from 996tt to Cayman totally different? I would think that the 996TT wheels would stick out too far.
Old 10-18-2010, 09:25 PM
wwjd's Avatar
wwjd is infamous around these parts
If you are going to put spacers more than 15mm on it, you might have chance to having rubbing issue.
Old 10-18-2010, 10:29 PM
Ray's Avatar
Ray
Ray is offline
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
for 11" wheels, you need +35 offset to clear shock. So a pair of 10mm spacers will work. But not sure 315 tires will clear.
Old 10-18-2010, 10:39 PM
Originally Posted by Tay Tay
are you lowered?
Yes,I have techart springs.
Old 10-19-2010, 12:41 AM
wwjd's Avatar
I used to have lower springs, and I can tell you 325/25 19 with 15mm spacers wouldn't work. I'm not sure 315 though.
Old 10-24-2010, 12:43 AM
cl997's Avatar
cl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to behold
I think you'll be rubbin'... either with the springs or with your fender (even if you rolled them).
Old 10-26-2010, 07:44 PM
CaymanSteve's Avatar
CaymanSteve is infamous around these parts
I was running 19x11 with a 315 tire in the rear on my Cayman S. Had rubbing issuses to the point that a rear blew out. Went down to a 295 in the rear. No rubbing.
Old 10-26-2010, 08:12 PM
lithium1330's Avatar
lithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud oflithium1330 has much to be proud of
Just curious, what's your offset?
Old 10-27-2010, 06:44 PM
19X8.5 +51 up front with 19X11 +38 in the rear, sits flush with no spacers. Lowered on Champion springs.
Old 11-06-2010, 07:07 AM
What size of spacers I ll need with 285-30-19x11 at the same wheel (45 offset).Is it ok a 9mm spacer?
Old 11-06-2010, 03:54 PM
Tay Tay's Avatar
Any Pictures?
matt2ace
11-23-2019 11:38 AM
MeddlingKid
10-20-2015 07:43 AM
10-06-2015 06:13 PM
Quick Reply: Cayman and 11x19
