3.2 - 3.6 engine build pictures
Old 10-24-2010 | 06:10 PM
Byprodriver's Avatar
Byprodriver is infamous around these parts
Original case from my 2000 S ready for some enhancements!
Old 10-25-2010 | 12:50 PM
Underside cleaned
Cleaned underneath
Old 10-25-2010 | 06:05 PM
extanker's Avatar
extanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond reputeextanker has a reputation beyond repute
when my po and garage were new they werent that clean
Old 10-25-2010 | 06:35 PM
ajb_unc's Avatar
ajb_unc is infamous around these parts
That looks awesome and so clean in there!
Old 10-26-2010 | 12:13 PM
Neither were mine, they always told me my U.S.M.C training would payoff someday!
Old 10-26-2010 | 10:16 PM
New Parts!
Old 10-27-2010 | 12:46 PM
chaud's Avatar
chaud is infamous around these parts
NICE! Looking forward to this build thread!
Subscribed!
Old 10-27-2010 | 03:52 PM
devious986S's Avatar
devious986S is infamous around these parts
awesome!
Please spend the extra time to take plenty of pictures along the way, it's always appreciated
Old 10-28-2010 | 10:33 AM
Crankshaft bearing housing & R&R rods
Here you go
Old 10-31-2010 | 03:33 PM
Crankshaft Bearing housing installed
Crankshaft Bearing housing installed in 1-3 cyl. case half
Old 11-05-2010 | 05:01 PM
L&N 99mm sleeves & JE pistons
New Pistons & 99mm sleeves
Old 11-06-2010 | 07:44 PM
looks great so far!
What are you using as far as throttle body, maf sensor, dme?
Old 11-08-2010 | 11:43 AM
Originally Posted by devious986S
looks great so far!
Thanks, in answer to your questions: original stock parts work fine but I will be looking for a good used 75mm T/B.
Old 11-11-2010 | 12:36 PM
New Swirlpolished valves & springs
Heads Up!
Old 11-14-2010 | 07:44 PM
are you planning on doing a few dyno runs after its all put together?
