Can I put Motul RBF600 brake fluid into a Boxtser?
I'm wondering if anyone here can tell me if Motul RBF600 brake fluid is OK to use with 987.1 Boxster S?
I'm looking to put in something more resistant to boiling, so help will be very much appreciated.
Thanks.
Thanks.
+1 make sure to flush out all the old fluid before you so.
I've used the Motul RBF600 in many cars, vintage and modern. As long as you flush the system completely so the fluids can't react with each other you'll be good.
The difference in pedal feel and fade resistance is impressive with this fluid. If you're still using OEM pads be careful though, you can over-heat them and get fade long before the fluid will boil.
still lost
Merchandise For Sale / Wanted
01-23-2017 02:04 PM
LiquidElephant
08-27-2015 07:17 PM
