Springs only? Or springs plus sway bars?
After years if thinking about it, I plan to install H&R springs on my 1999 986.
Should I stop there? Or upgrade the anti-roll bars as well?
The toy is used in the warm months (CHI) for spririted driving and autocross.
Thx.
Thx.
#1 Best bang for the buck to improve handling on a 986? Add M030 rear sway bar only. Next best bang for the buck? M030 ROW kit complete. If your struts are 12 years old with 50k+ miles they are pretty well gone and due for replacement.
My car is currently set up for competition Time Trials with PSS9s and comp sways. As I developed the car I started with sways only and the rear M030 made a big difference, front not so much. As an instructor I do about 20 track days per year and drive/ride in cars with lots of different suspension setups. My impression of different setups over the years:
Bone stock- Good predictable handling with a lot of push.
Stock with rear M030 sway- Good predictable handling with better balance, a lot less push.
Stock struts/lowering springs- A bit unpredictable with bump steer issues. Often worse than stock, possibly due to flawed setup and corner balance.
M030 ROW kit complete, pro alignment- Very balanced and precise handling, no push.
PSS9s, comp sways, pro corner balance and alignment- Very balanced and precise handling, no push, adjustable to different drivers and track conditions. Big $$$
Running on street tires I think the M030 ROW kit is every bit as good as my competition setup at about 1/3 the cost. Far far better balance and handling than lowering springs. I highly recommend it. If you run sticky R-comp tires you may need the adjust-ability of a comp suspension system.
Thx, Cajun.
Finally got the toy back from the dealer (took 2 weeks!) and the H&R springs are phenomenal. Ride quality is near stock (unlike the springs I put on my 955), stance is beast (w/ spacers), and it corners flat as sin.
I need to auto-x soon to see if I experience the push, but I know how to cure it w/ your gr8 descriptions.
As the Jets LB once said...CAN'T WAIT!
proTUNING Freaks
09-15-2015 07:28 AM
