Will these fit
Old 02-03-2012, 04:07 PM
GETU1's Avatar
GETU1 is infamous around these partsGETU1 is infamous around these parts
Will these fit
I searched a little, sorry this might seem like an annoying thread.
Front- 19X8.5
Rear- 19X11
Offset: Front +56MM
Rear +67MM
Lowered on H&R springs. What would the widest rear tire I could run with that setup? Thanks, 2008 cayman S
Old 02-03-2012, 04:11 PM
GETU1's Avatar
Or will these be better to go with
Front- 19X8.5
Rear- 19X9.5
Offset: Front +56MM
Rear +46MM
Old 02-03-2012, 05:03 PM
alex911s's Avatar
alex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond repute
your 1st option would need at least a 23mm spacer.. 2nd option is good but might be better with additional 7mm.. offset 38 is the best rear fit i've seen with H&R.. fronts are fine.
Old 02-03-2012, 05:27 PM
GETU1's Avatar
23mm spacer even with an 11'' wheel? Alright, I will factor spacers into the cost of this. Thanks
Old 02-03-2012, 06:01 PM
damon@tirerack's Avatar
Moderator
Front is fine, rear will be fine with a 15 or 18mm spacer. Beyond 18 and you get into adaptors, which I don't recommend.
I have 15 and 18mm spacers and bolts if you need them. $104 a pair, bolts $6 each. Please call me if interested.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old 02-03-2012, 06:04 PM
GETU1's Avatar
I assume you are referring to the 11'' rear set up? Thanks, I might have to take you up on your offer.
How would the 9.5" rear look @ 46mm, close to flush?
Old 02-05-2012, 09:29 AM
MileHigh986's Avatar
MileHigh986 has a spectacular aura aboutMileHigh986 has a spectacular aura aboutMileHigh986 has a spectacular aura about
It's not annoying, just repetitive. 11" wheels won't fit. Even if you can get them in there, you can't drive it. Period. It would require extensive fender modification.
Old 02-05-2012, 09:22 PM
Stephen S's Avatar
Stephen S is infamous around these parts
I have 11 in width rear wheels on my 06 Cayman S. They are just fine.
Old 02-05-2012, 11:42 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
If you have lowered springs and 19X11 rear wheels - post a photo. It won't happen.
Old 02-06-2012, 12:48 PM
Jon70ProofZ's Avatar
Jon70ProofZ is just really niceJon70ProofZ is just really niceJon70ProofZ is just really niceJon70ProofZ is just really nice
Glad I found this, was about to buy some 19x11 rears, but they are +38. I think it will stick out too far. I'm not lowered and dont plan on being that way ever, but I dont want to be handicapped by a wheel too big.
Old 02-06-2012, 06:46 PM
The Youngn's Avatar
The Youngn is infamous around these parts
I'm running 18x11 rears, offset totaling +30, very meaty tire and H&R springs on my 06 CS with no problems at all.
Old 02-27-2012, 10:36 AM
john rice's Avatar
john rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to behold
I second the request for images.. please! I went through this decades ago fitting 9x16 930 wheels on the back of a Carrera. At the time all the experts swore they would not fit. A friend swapped wheels and I tried on his 7+9x16s with 205/245s and they were perfect. And, yes, the car was lowered.
In this context, it would be super if a couple of you guys running the 11's would post some images AND wheel specifics, spacers if any, tire brand/size, AND.. last but not least, what type springs/ride height you are running.
Right now my wifes 987S has 19" Ruf 8.5 + 10. I had a tire issue and slapped a way oversize rear tire set, just because they were sitting around from my GT2. Too large? Probably, but they look, fit, and work fine. I have a set of H&R springs that the car may get and that may make me rethink tire sizes. ;-> The point being that there are a lot of variables and I can swear that a 305/30 is FINE on the rear of a Boxster S and it is, but perhaps only if you leave it at the Factory "too high" ride height.
So.. any specifics about 11s on the rear???
JR
Old 04-10-2012, 01:46 PM
john rice's Avatar
Awwww guys... You tell us how well 11s fit BUT not one of you will post any images and details??
I gotta say it. This would never happen on the GT2 board. Never.
Show some 987 pride and post image, OK?
JR
Old 04-11-2012, 08:02 AM
The Youngn's Avatar
18x8et50 with 235/40's up front
18x11et30 with 285/40's out back
lowered on H&R springs
In retrospec, I should have gone with a smaller rear tire. Whenever I turned real hard or hit a large dip in the road then I would rub.
Old 04-11-2012, 08:25 AM
The Youngn's Avatar
19x8et30 with 225/35's up front
19x11et 25 with 265/35's out back
First pictures are lowered on the H&R springs and the last picture is lowered on PSS9's. I'll get some 3/4 shots and post those up sometime soon.
I rub just a tiny bit on really large dips but gonna dial in a little more camber and that'll fix the rubbing issue. Also going to roll the rear fenders as well.
Quick Reply: Will these fit
